fullvietFX
- Sep 1, 2004
If AMD releases something that's good as my 2600K clock-for-clock and uses the same or less power I'm switching back to AMD no matter the cost.
Well I am loving my FX 8320 and FX 8350, I will definitely be upgrading at that point as well. I see no reason why it would be any less than at least a 4770K even if they probably will not equal whatever Intel has out at that point.
The chances of anything AMD produces coming even close to a 4770K is about the same chance as Keira Knightley showing up at your door in the next 15 minutes and offering you a handjob. There's no suspense when AMD conceeded the desktop, server, and mobile markets to Intel publicly 3 years ago.
But... if the original bulldozer plans are to be believed and the target was 8Ghz, then it isn't that AMD wasn't planning on keeping up but rather the process at GloFo didn't quite make it happen. Now with new management and hopefully a keener and rational sense of reality in the process and GloFo it is very possible that the next AMD CPU will in fact equal or surpass the 4770k.
Side note: Has HSA compatible software released yet ie:Java?
For most things iGPU performance is more important than CPU performance which is already overkill.
Proof? Do you have insider knowledge on such things? Please, show me your evidence that AMD cannot produce something that will "even come close" to a 4770K? Nothing? Eh?![]()
If AMD does not produce a new competitive desktop chip, it's because they decided not to for whatever reason, be it financial, miss-management or just plain bad ideas..
Considering they probably started planning it somewhere around time when A64 was kicking ass of Pentium IV due to Intel running into frequency wall then AMD upper managment was even bigger bunch of utter morons than anyone suspected.
That's not a matter of "deciding to" or not. You think their execs wake up in the morning and decide to fail? Everything you list is the core of what makes up a business. If they fail as a business it's because they sucked as a business, not because they "decided" at some point they were going to give up.
Reminds me of people who get fired and scream out "I QUIT" like it makes a difference.
3. GRANT OF RIGHTS
3.1. AMD License to Intel. Subject to the terms and conditions of this -------------------- Agreement, AMD hereby grants to Intel a non-exclusive, non-transferable ***** worldwide license, without the right to sublicense, under AMD's Patents to: - See more at: http://corporate.findlaw.com/contra...cro-devices-inc-and.html#sthash.Yd8cnXn3.dpuf
All blame for greenlightning Bulldozer architecture falls on AMD management and there are no excuses for that.
The original Bulldozer looks to be intended for 8Ghz operation
Phenom was at a wall, it had nothing left. Even as good as it was, it could add nothing more.
8Ghz was the target and again there is no clear information as to why it was and to the likely-hood of its fruition. And R&D does not speak to innovation. It only speaks to the ability to move it forward. It isn't hard to tell that AMD has a lot of innovation over the years, as in thinking outside of the box, just the Funds fall short in getting them implemented in a timely fashion. Unfortunately they have to rely on the community to get these ideas to market ie: HSA, Mantle (which is going quite well), Adaptive-sync, HBM and the like. And with all that R&D that Intel has what have they brought that wasn't just an iteration of previous tech or someone else's idea?
At the end of the day I can play any game out there fine with a good graphics card the same as any Intel cpu. Maybe not as fast in fps but there is no bottleneck. I do have i7 cpu's also.
Point is an FX cpu was not a horrible choice for those who bought one. It gets the job done.
No , 8GHZ is so far fetched it is out of the realm of possibility. You abuse the word innovation. you might as well be a conversation bot.
So do you have any real discussion points to counter? As you can see Naroon backed up my claim as far as 8Ghz, which at the time they probably thought was an eventual outcome, no matter whether it was ill-informed or not.
As far as innovation, how would you dispute Factually?
Find a financial report from AMD where there is no positive undertone, where you state something which is a "possibility" to people who want to invest money into you company you use certain tactics. That is the only way the 8 GHZ could ever come into play because there is nothing from Global Foundries or others that would even suggest that this would be possible
Google : Microsoft Innovation and get 57 million hits.
Innovation in making a CPU is something AMD did with APU currently the only thing they did right. Sadly this does not translate magically to anything that would describe your point of view about it being a possibility in the realm of the CPU.
For it to break boundaries you need something as this . Making a cpu from the same materials as others limits you to the same problems. AMD won't make a cpu that can do 8GHZ in the consumer space any time soon.
To break down Innovation for cpu look at the gpu. the gpu scales a decent amount each OEM cycle and the cpu just goes at a snails pace compared to the gpu. In other words it will be a very long time before we see a single cpu do 5 Teraflops as what is done now on 1 gpu.
There goes the innovation in the cpu market ....... There are 2 in snail race where one of the competitors is 4 millimetres ahead of the other and declared leading by light years.
You need to open the field of view here. You are limiting innovation to hardware only. I did mention HSA, Mantle ( a little less innovative granted, as in done before) HBM. Then you can go back to 64 bit procs, that work. The 512 bit bus on the 290s that no one expected or the AIO on the 290X. Innovative generally means moving forward and at times changing the way it is done enough so the market starts to desire that change. It doesn't always mean the first to invent.
As far as the 8Ghz it doesnt have to ever rely on a sales meeting. It was the intention of the engineers and quite easy to see in the design as the intended speed. Of course we now know that it wasn't going to happen, hind-sight, but as I said looking at the design it makes everything about the design @8Ghz make sense.
HSA Mantle do not pay the bills. Are the 8ghz engineers the same ones that have been let go in the not to distant past because that would explain things.....
And yet you fail to see beyond the 8 ghz that is why I told you before that even a Phenom II at 8 ghz would be great. It was never going to happen not any design at 8ghz. Because nearly everything scales when you ramp up the clock speed, so why would Bulldozer all of a sudden have magical things happen at 8 ghz?
Is it the same failed logic as displayed by JF-AMD when he was yelling something about boosting clock to gain IPC???
To give you a good impression if you run most of the games which are still largely not that optimized for multi core you would need a lot more then 8GHZ to beat up Intel..
Mantle on Linux would be really nice. So far a few titles been here with Mantle and lets hope they keep on coming.
