i'm running my x2 at 1.55v @ 2805 with load temps at around 52/53 on stock cooling...
i've reading around and everyone is OMG! dont push them over 1.5 volts, i cant seem to see what all the fuss is about, if on stock cooling the temps arent that excessive whats the problem, i really doubt electron degradtion will occur at this low of a voltage and heat level.
whats the max vcore you've seen these chips run at, i'm aiming for a 2.9ghz overclock with a zalman cnps9500 am2 cooler as soon as i can afford it...
