AMD X2 5000+ AM2 $81 Shipped
Oddly enough it appears to come with Stranglehold as well for the same price. Check the combo box at the bottom.
Thanks. This is perfect timing. I was just about to order a 4000+ OEM and add an aftermarket HSF, but this is a way better deal.
Also, FYI, if you want to forego the -$8, you can get "Stranglehold" PC game for free. I actually opted for the -$8. :p
No hsf with the black ed., and it's going into a my girlfriend's budget PC. OC is out of the question. I was considering it as well, but I rather not deal with the headaches if the heat or stability issues. It's going into a microATX IGP board in a microFly case.
Fair enough, just not necessary to spend more money on same product (if you're not overclocking). + spend more on heatsink (I had no idea it didn't come with one).
I've been a subscriber for years.
I even logged out and back in, and it still says it's for specific programs. Then I tried clearing the coupon, logging out, and logging in after applying the coupon, checking the box to sign up for the newsletter, and still it won't work.
Promo code still won't work for me. Figures, though. I just built my parents a rig with a 4800+ Brisbane. Guess I can't regret it if the promo code won't work. :D :(
you guys think that this will help decode blueray (vc1) better that a be-2300 (x1 1900mhz) on a geforce 7050 mobo?
Yes, a lot. That being said, if you need lower power consumption (the whole point of the BE line), it's probably not the best choice.
If you're only decoding to playback, maybe a low end graphics card which will fully decode 1080p in hardware (like a 3xx0 series AMD card with UDV) would be a better choice (less power consumption, less heat, less cost).
so this comes with the mother board? where do i get specs on it? does it have a soundcard? SATA?
agreed, best option is probably to stick with your BE-2300 and add a 3450 for $50 bucks. Recent reviews are showing the 3x series offloads almost 100% of h.264 and VC-1 decoding and it's built into the driver so you don't have to only pick software that's written specifically to support it. Previous cards that listed h.264/vc1 support were very finicky with offloading depending on what codec/software was being used but with the new 3x series, it seems to be working seemlessly. You can also run the BE series fanless and have no heat problems and also have a super low powered and quiet system that way.
anyone here have a recommendation for a sub $100 mobo that has great OC potential with this proc (has Crossfire)
