Please help i,m at my wits end and cannot find a solution.
At the moment i am running Windows XP with SP2,CPU AMD 64 3200, Colorsit 600W power supply, Radeon X300 Graphics card, 1024 Ram (Corsair value Pc3200), 50and 80 Gb Maxtor drives, Winfast 2000 TV Card and Soundblaster live audio card.
Running no problem encountered.
Decided to go dual core, because burning DVD,s used all processing power and had to wait for burning to finish before i could access any other programmes.
Motherboard is ECS nForce4 A939 which supports Dual Core. So i purchased a AMD 939 Socket X2 4200 dual core. Read in forums about updating all drivers to support d/c and flashing BIOS. All Hardware updated and bios flashed to latest 1.1k and installed processor with reinstall of windows.
Now PC keeps shutting down and restarting at 45min intervals with no blue screen or warnings. The only thing that happens is the screen and mouse freeze for about 3 seconds,then restarts. Checked CPU temps memory tested removed everything from mobo except graphics card and 80 drive(need screen and operating system) still shuts down.Checked power saving settings,ok.
Ticked "donot restart with error" looked at Event Viewer no problems.
CAN ANYONE HELP PLEASE! before it end up on a bonfire......
