AMD Wraith cooler overclocking
Trivium
Just wondering if any of you guys are running the AMD wraith cooler with an overclock? I'm wondering how it compares to aftermarket air and lower end liquid coolers. Currently have my 8370 OC'd to 4.5ghz, but I'd like to get more out of it. My case is limiting my to a single fan liquid cooler though (Corsair H60). Got the Wraith cooler sitting around, but don't know if it's worth even trying it.
IF I recall correctly the wraith is just below the 212evo and that is about on par with a H60. my guess would be that the wraith would give you about the same OC with just a bit higher temps, prob less than 5C. if you can add another fan to the h60 for push/pull that would help a bit. or if you upgrade the fan on the wraith, hmmm...
