AMD vs Intel
OPUS1
This has been asked over and over and over....
Please No flame war
I want to build a daw/3d graphics/ gaming setup
Win 7 64bit
And my friggin head is spinnin.....
It looks like Amd offers some great stuff at a great price break...
What does reality say?
Kiss it ok!
(keep it simple)
Dude, you're gonna get a flame war considering the question you asked. It's unavoidable.
Anyway, for straight up gaming, AMD would be the better choice in terms of best bang for the buck. For 3D rendering and DAW work, you're gonna want as fast as a CPU as possible. As such Intel's Core i5 and Core i7 CPUs are your best choice.
Frankly dude, just do some research on which CPU performs best for the DAW and 3D applications you're gonna use, compare the prices and figure it out yourself. Not that hard.
Basically what Danny Bui said. I'd go so far as to add, however, that Intel will provide the best performance no matter what you're doing. AMD will be least expensive.
I say wait for the Phenom II 965 C3 to hit the markets. In my opinion, I'd always go with AMD for the price and their performance, I know and admit that Intel beats AMD in performance in every way, except for their prices are like hell dude, you could get close to i7 with the 965 C3 and simply OC to 4.0GHz+ even on air.
From Phenom 965 C3 NDA is Lifted Thread:
Well it's the 4th now and we've all been waiting patiently enough.
Review by Chew from XS.
http://www.techreaction.net/forums/s...ead.php?t=1204
http://www.xtremesystems.org/Forums/...d.php?t=238230
Air cooling: 2 hour Prime95 stable at 4.1GHz / benchmark stable at 4.26GHz
Water cooling: 2 hour Prime95 stable 4.2GHz / benchmark stable at 4.34GHz / some screenshots at 4.6GHz and 4.7GHz
IMC improvements: RAM -> 6-7-6-18 1T @1880Mhz at stock voltages
NB overclocked to ~3GHz with voltage increase
Almost 14,000 MB/s Memory Copy speed in Everest
He has some pretty insane RAM though so don't expect that with a <=$100 kit.
There's also below ambient testing on phase change, dry ice, and liquid nitrogen for those interested.
AMD motherboards also cost so much less than Intel's...
I'm just giving in my opinion, this is completely your choice with what you want to buy with your money, just giving in some advice. :)
Good luck
Tj
OP it will depend on your how big your wallet is.
Intel = Has the performance crown
AMD = Has the performance/price ratio
If your budget is something like $600 your better off with AMD.
If your budget is something like $1500 then go for Intel.
It is not about which company is better but which company is better suited for you.
Thank you.
well dang was going to come up with something.. but i just cant compete with this post.. DTN hit it right on the nail.. nice post man..
