AMD upgrade, question about memory compatiblilty
dogbyte_13
Ok, getting new parts this friday and have eveything else so this is what im getting, first im using built in grafix card for now, second will this memory be ok? im used to back in the old days where u didnt have to worry about memory compatability, second gaming what would be a good video card for this once i get the extra money to upgrade a 8800GTS or a GTX series? so any input would be great. and will this cooler fit it, the website says so but you never know. link
Processor
Motherboard
Memory
Processor
Motherboard
Memory
Back in the day, memory compatibility was a huge issue, especially before SDR and DDR SDR was out.
The RAM/Mobo/CPU are all fine.
That cooler will only work with Socket 939 setups. You have chosen and AM2 setup. Socket 939 has been discontinued for a while now. Will you be overclocking? If so, pickup a Scythe Ninja Plus Rev.B, Tuniq Tower, or Thermalright Ultra 120 (extreme) plus Scythe S-Flex fan. Otherwise, the stock HSF should suffice.
