amd system not posting and making grinding noise
micronix
I built an amd xp2400+ system a few years ago using a soyo kt dragon 400 board. The cpu is topped off with an automatic volcano 7 fan and the system is powered by a generic 400w psu.
After a few days of downtime, I turn the system on and notice that it powers on, gives a long beep, gives off some kind of grinding noise, and then just powers right off. The cpu fan is still spinning. the power supply fans look fine, and I tried disconnecting all the drives to make sure that they weren't related. Same problem. Power on, long beep, long grind, and power off.
What the hell is going on?
polish twin might be right, hold your videocard fan and still if there is still griding noises. if not then its ur videocard.... ;) replace it soon before it dies
are you able to figure out what makes the grinding nouse? what about vid card fan?
Video card fan, right. I'll definitely check that out tonight when I'm back with that system. I was so focused and worried about it being cpu related that I completely forgot that the system wasnt using low profile cooling on the vid card. It's a radeon 8500 with the stock cooler.
Thanks for pointing me in the right direction.
Definately check your fans for the source of the noise. The only other moving parts 'should' be your HDD and any CD-Rom Drives that you have. If it is not the fans (Vid Card, PSU, or other) then make sure there is no disc in your CD Drives and boot. If you still hear the noise *gulp* its probably your HDD.
If you are getting a POST Beep, go to the MOBO manufacturer's site and find the list of post codes to determine what the beep means. It isnt always right but it may give you an idea of where to start.
Good Luck!
Good Luck!
I disconnected all the drives to isolate the problem. It's between the power supply, cpufan, and video card fan. I'll have to check the video card later tonight. As for the the beep, it's just one long beep.
One beep and nothing come up on the monitor
To resolve this issue:
1. The monitor is not plug in correctly. Please check the monitor cable and be sure it is connected firmly. If the problem still presist, please try another monitor.
2. The Bios settings may not be set correctly.
To correct this problem try turning the system on while holding down the "Insert" key on your keyboard. Once the system comes up, hit the "Del" key and select "Load Optimised Defaults", hit "Enter" then select "Y". Then choose Save and Exit.
http://www.soyo.com.tw/kb/kbdesc.php?id=174
From what I've seen, the system never powers down by itself if the monitor is not plugged in correctly. Resetting the bios via software is not an option because the system wont power on. Also, the grinding noise.
No wonder soyo is exiting the motherboard market.
:rolleyes: they are a little moronic aren't they...
my guess would be the cpu fan actually... but try to power up the system with the door off and see what ain't working. that'll be your prob.
The cpu fan spins up fine. The power supply fans look good too. I'm starting to think that it may be the video card because I didnt get a chance to look at the fan on it yet, but would that cause the system to power on and then shut off after a long beep and grinding sound?
