AMD system build $700-$800
Ilumine
Building a system for a friend, and decided to go AMD because I don't want to spend a whole lot of time on the OC. Problem is I'm more of an Intel guy and have no idea whats out there right now. He's looking to spend $700-$800, and will be using it for school and gaming. His monitor is a 22in lcd, so I'm prob going with the 5770 as the vid card. Any help on the other components would be greatly appreciated.
thanks for the tip! Any guesses as to how many of the cores I could potentially unlock based on other users experience?
the above setup is good, when i get home in a bit ill send another one your way, with a bit more power.....other than a few little things, there are some good deals in the above mentioned post
guess on unlock: probably 2.....though its hard to be certain since it depends on the batch.
I wouldn't buy a Dual Core and try to unlock the cores, Just go with the quad core and be done with it, if your budget is 800, get something like these parts listed below. And don't get him the 5770, its barley faster than a 4870. At 299 the 5850 is a really good deal and plenty fast for a 24 inch monitor upgrade in the future.
CPU
http://www.newegg.com/Product/Produ...m_re=955_black_edition-_-19-103-808-_-Product
Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402
Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145299
Ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
Video Card
http://www.newegg.com/Product/Produ...2884&cm_re=Radeon_5850-_-14-102-884-_-Product
or
http://www.newegg.com/Product/Produ...1351&cm_re=Radeon_5850-_-14-131-351-_-Product
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
Starting to get an idea of what to buy, just a few more questions. How does a crossfire 5770 setup compare to the 5850, and would a 6gig ram setup be noticably faster in games than a 4gig build?
number of games than need more than 4 gb is fewer than 2% range
crossfire 5770 would be little faster than a single 5850 but that is depend on the game as not all games scale well in crossfire.
Not since most game are only 32bit, they can only address 4GB or less.
A pair of Crossfired 5770s will stomp a 5870 (And a GTX295, 4870x2...) in most games.
See here: http://www.guru3d.com/article/radeon-hd-5770-review-test/1
thats around the price of my new system build except the HDDs, i have 4 satas already, i have the case already as well
i went with the X4 965, offers just a tad bit more over clocking capabilities
also if you wait a couple weeks, the NEW 890fx boards come out, along with the Asus Crosshair IV :) which are all upgradable to a 6 core CPU
splurge on a 5850, i did and couldnt be happier, you can get a sapphire on newegg that comes with a free Steam copy of Modern Warfare 2, absolutely love this card
make sure you get a good power supply, preferably one thats modular, since in the long run it will save you money on your electric bill
and get a copy of Windows 7 to unlock the DX11 goodness
the 955 actually is a better Over-clocker....
anyhow
6 GB wont give a noticeable difference, don't waste money(since you are probably referring to a 6 GB kit, which is typically a tri-channel kit....whereas AMD can only as of now incorporate dual-channel memory......and i think on AMD boards if you run a stick solo[not with another] you will only get single channel)
and a xfire 5770 will be faster as said, though the recommendation to get a 5850 is a better choice because you can then get another 5850, especially since a 5850 is more than overkill for a 22 inch monitor
edit: modular wont really reduce power bill....it just makes cable management alot easer, but the modular PSUs are typically marked up, i love my Antec TruPower 750, got it for $70 on sale :p
