Scenario:
I have 3 SSD's. I want to use the small SSD for a boot drive in AHCI mode and setup the other 2 SSD's in a RAID-0 config, using the SB950 controller. However, it seems that I cannot have 1 SB950 Sata3 port set to AHCI and the other SB950 ports set to Raid. I can control Ports 1-4 and 5-6 separately. However, 5-6 only can manually be set to AHCI/IDE (if 1-4 are not set to RAID), but once I set ports 1-4 to Raid, 5-6 also go to Raid. Can I run a single drive off a raid port and if I can do I lose Trim on the single drive? I know I won't have Trim on the Raid-0 on the SB950.
Alternatively, would I notice a performance issue if I just leave the single drive set to AHCI and skip raid-0 on the SB950, and just use Windows 8 software raid to create the storage array? Using FX-8350 for CPU. I should add the Motherboard is Asus 990FX Sabertooth Rev1.
Thanks for any input.
