DeChache
- Oct 30, 2005
Yeah, like 4 X 4 and 65nm being kick-ass?
Why do I get the impression that you like to start problems.
No it's not.... The 286 is a completely different architecture....
It was completely redesigned with the 386, then again with the PPro. We've been with the PPro ever since then
Yashu [H]ard|Gawd
Maybe we should trust AMD.
They said similar things about k7 and k8 and it was proven to be true.
Still, I didn't bring up issue of heritage. I merely responded to it. Savantu likes to peddle the idea that K8L can't possible be as good as Core2, because K8L is based on K8 and Core2 is "all new" (not based on original Core or earlier). Even if one were to (incorrectly) assume that Core2 is "all new", this assumption has no effect on performance whatsoever. A new arch can perform just as quickly/poorly as an updated older arch. The whole issue of core heritage is a total waste of time IMHO.
Actually the move from 286 to 386 is not much different than the move from K7 to K8 (or Northwood to Prescott if you like).
The actual CPU-design wasn't all that different. Slightly more cache (or well, the instruction-'cache' was just a tiny look-ahead window on the 386), and not much difference in terms of speed/IPC.
Main difference was the 32-bit mode.
And between the 386, there were also the 486 and Pentium which were considerably different. Especially 486 and Pentium are worlds apart (move to superscalar, and first steps on RISC-like dissection and execution of x86 instructions).
Pentium and Pentium Pro are also entirely different concepts (synchronized two-issue pipeline versus out-of-order execution with independent 'instruction ports' rather than a single pipeline as such).
QFT!Why do I get the impression that you like to start problems.
IPC wasnt that much better, but the pipeline was significantly overhauled due to the attempt at a scaler pipeline. It was a complete redesign in the way an architecture handles data.... The 486 was a 386 with a different name. The pentium classic was a failed attempt to make the existing 386 pipeline superscaler.
Core was limited to ~2.5 GHz with the old pipeline length. Part of the reason why Core2 is such a good overclocker now is because the pipeline was lengthened by a few stages, which gives it a lot of headroom.
Other than that I think trying to improve on x86's IPC is flogging a dead horse. I'm quite impressed that Core2 beat even the K8's impressive IPC, but I don't expect AMD to go much further. x86-code doesn't lend itself well to parallel execution because it was never designed to. So throwing everything at trying to improve IPC, while working with a low clockspeed limit is a bad move in my opinion.
Intel had a good idea going with Pentium 4, but they overshot their goal... The Core2 is much more conservative, but still aimed at clockspeeds well beyond 3 GHz, and that's where K8L is going to take a beating, I gather.
No , Yonah has a 13 stage pipeline and Core has 14.
Yonah was limited to 2.33GHz simply because of TDP.
Other than that I think trying to improve on x86's IPC is flogging a dead horse. I'm quite impressed that Core2 beat even the K8's impressive IPC, but I don't expect AMD to go much further. x86-code doesn't lend itself well to parallel execution because it was never designed to. So throwing everything at trying to improve IPC, while working with a low clockspeed limit is a bad move in my opinion. [. . .] The Core2 is much more conservative, but still aimed at clockspeeds well beyond 3 GHz, and that's where K8L is going to take a beating, I gather.
I can't say I disagree. Clock speed is AMD's biggest problem right now, and the 65nm transition is not going to give them much, especially at introduction.
http://i18.tinypic.com/4cv04d1.jpg
You people need to pull your heads out yer [butts] and face the fact that competition breeds better products.
Sure they made improvements... No question about that, but the architecture was fundamentally the same.
Yonah was limited to 2.33GHz simply because of TDP.It had to fit inside 31w and the entire chip was designed accordingly.
It was 12 stages,....
I am starting to become a believer in these latest claims from AMD.I think that this new chip will be 80% faster then current and soon to be released C2D/C2Q's,but this will be AMD's last hurah of sorts,if they cant grab and hold real market share with this new line of chips.....
It's 13.There's no official info from Intel on how many stages Banias/Dothan/Yonah has except a comment : longer than P3 ( 10 ) and shorter than Core ( 14 ).Some folks at Aces did some tests and concluded 13 is the most likely.
The Intel camp plays the role of libs, and AMD plays the role of repubs.
I would have said it was the other way around.
Intel is a big bloated buerocratic empire that slowly reacts like the republican administration. AMD is more streamlined, slightly indecisive, aimed at the less rich, and kindof an underdog like the liberals. AMD also had the "grass roots" support for a long time - another trait of democrats.
I don't know how AMD can be said to be more like the repubs... unless you are basing it all on the fact that they are based in texas.
What K8L will have to deal with.
http://hwzone.co.il/english-reviews/intel_apc_2006-eng/
Of course AMD and many folks here thought 4 X 4 would restore the Greenteam some pride. Others here suggested that just going to 65nm would get more MHz and the result would be a Closing of the GAP. Guys, don't shoot the messenger here.
there are teams?
AMD's Barry said that machines with the new sockets will be to run multithreaded games at better performance levels than Intel-based machines. He said that more game companies have begun to adapt their games to exploit multiple threads in a PC, allowing them to handle more tasks at the same time and thereby run much games faster and prettier for gamers. "
visaris said:I would be very surprised if a single Conroe XE would outperform two FX-64s across the board. This puts the 4x4 platform as the best money can buy on the desktop. Conroe may still have the best price/performance ratio, and this may be even more true of lower clocked models, but the FX and XE lines are not about being the best price/performance. These lines are all about being the best performers.
The video Sub system will be the key to any advantage AMD will have here, NOT the processors. Unless many of you believe this was faked or poorly done as well.
Maybe it got lost in all the flames, but I also haven't seen anybody mention that AMD has a MUCH more efficient multicore architecture. I wouldn't be surprised in the least if AMD achieved better quad core performance relative to their dual core designs than Intel did. That could also lead to a large gap in benchmarks which adequately utilize all four cores.
He means Barcelona will be four cores on one die, with efficient interconnects. This is arguably more efficient than Kentsfield's two dies which talk to each other through the FSB.
Ummmm...eventually Intel will move to a single-die, quad-core Core, with "gimmicks" like interconnects as improvements.I mean AMD better worry about Core improvements and NOT gimmicks like interconntions and Native BS! Of cource I know what he meant.
The desktop equivalent of Barcelona, codenamed Agena, is the 65nm flagship of AMD's next-generation desktop processors. Launch frequencies were quoted at "2.4 - 2.6GHz." Previous roadmaps had indicated Agena would debut at 2.7 to 2.9 GHz. Agena will have a 2MB L2 and 2MB L3 cache per CPU. AMD's internal guidance denotes this as a 125W TDP processor. As the flagship, Agena will be the first next-generation desktop launch and is scheduled for Q3'07.
