AMD Ryzen Threadripper Cooler List
FrgMstr
Just Plain Mean
Staff member
As previously mentioned, there is a liquid cooler bracket included in the processor box. This bracket is intended to make Asetek-based design liquid coolers compatible with the Ryzen Threadripper processor and SocketTR4. The coolers listed below have been tested by AMD and work well with Ryzen Threadripper.
You may notice that the head or block of the thermal solution does not completely cover the integrated heat spreader (also known as processor lid) of the Ryzen Threadripper. This is acceptable because of the
thermal performance of the listed coolers, and the fact that the head covers both silicon chips under the heat spreader. To ensure best performance, please ensure the thermal paste applied to the head spreads evenly and completely across the surface of the head to use the full contact area.
Liquid Coolers:
- Corsair Hydro Series H115i / H100i v2 / H105 / H80iv2
- NZXT Kraken X62 / X61 / X52
- Thermaltake Riing 3.0 RGB 360 / RGB 240 /
- Thermaltake Water 3.0 Ultimate / 3.0 Extreme
- Cryorig A80 / A40 Ultimate / A40
- Arctic Liquid Freezer 240
- EVGA Closed Loop CPU Cooler (CLC) 280
Air Coolers:
- Arctic Freezer 33
- Coolermaster Hyper 212 EVO
- Noctua NH-U14S TR4-SP3, NH-U12S TR4-SP3, NH-U9 TR4-SP3
AMD Threadripper and TR4 X399 Motherboard Pre-buy
AMD Ryzen Threadripper 1950X (16-core/32-thread) - $999-Amazon - $1000-Newegg
AMD Ryzen Threadripper 1920X (12-core/24-thread) - $799-Amazon - $800-Newegg
And you are going to need a X399 Motherboard as well. (5 X Newegg)
If I recall correctly, due to AMD's strangely loose mounting system, the Coolermaster 212 EVO will slowly slide down or rotate over time until it's not touching the CPU optimally. I think it took 3 years, but in my brother's system, that I built, it rotated and so it was seeing wonky temperature readings until I realigned it. I'm not sure how well the others stay in place, but that one will slowly move. Also had an Earthquake here, so maybe that helped push it along as well.
