ccityinstaller
- Feb 23, 2007
you're missing a clamp off the resevoir on the right side.
Thanks but I actually don't need it...I used them out of an abundance of caution but one broke so I just left it off. The 90 degree fittings are larger then the ID of the tubing so that the tubing has to be heated and "stretched" into place of the fitting. This type of mount ensures the tubing is nice and tight, but it's a PiTA to get on properly.
