AMD Radeon HD 6950 to HD 6970 Mod
It's waking you up at idle? What on earth? Just force it to 20% speed. Silent, and it won't overheat [unless the clocks have bugged at 500mhz, check first, haha]
Yeah I had to force the fans down inside a custom TRIXX profile because I woke up thinking I left a fan on. I was shocked, but I also have to remember I did move my 800D case to my desk, outside it's desk floor cabinet.
Anyone have a link to the modified 6950 bios?
This thread should help you out.
http://forums.techpowerup.com/showthread.php?t=137136
I still can't get the memory to run stable above 1325 even with a different 6950.
I have 925 on the core @ 1.16V.
Do I need to use the 6970 bios to reach 1375? I'm using the shader unlock bios.
what should i use to test my shader unlock? i followed the steps and so far so good at desktop, but i want to run a stress test to be sure. i hvae it at 880mhz and 1350mhz ram :).
May want to update that sig. :p
yes but i still have that q9450 rig doing seti work, maybe not with 5870's :)
any ideas what i can do for stability testing? i've done 3dmark11 a few times, and full screen youtube, no problems or issues. furmark for 5-10 min and if its fine then it should be good? :)
can i run the 6950 oc and unlocked crossfired to a 6970? may just get a 6970 later on once they are cheap :)
