Brackle
Old Timer
- Jun 19, 2003
I was reading around other forums, seems that Corsair HX850 can run this setup, is that true? lol.
I don't see why not. My antec Signature Series 850w is having no issues running Tri-fire
Great! Can you tell me your temps? My GTX 580's were supposed to run cool but it runs pretty hot. I'm thinking of returning them for a tri-fire set up. How does BF3 play for you if you have it?
After playing 3 hours of BF3, My 6990's would stay around 76c, and the 6970 would stay around 71c.
Do you have them sandwiched close together? or slot 1 and slot 3?
Okay, so judging by this motherboard (which I have):
http://images.anandtech.com/doci/4330/ASUS Visual Top.jpg
That should be fine?.
I might need some extra fans in my case. My GTX 580's run around 80-95 degrees! But taht could also be because the GTX's run hot as hell.
So if I put it in slot 1 and 2, it's fine. Is that how you have it? It seems pretty close to touching would it not? Haha sorry for all the questions!
Unless you have an nforce 200 board - they're not strictly necessary but they do allow 16+16 with Sandy Bridge CPUs. The rule still stands though, because if you're using a 6990 and 6970, you want the longest cooler at the top for the best cooling potential (and reduced noise).
You really are thick as two short planks aren't you?
http://www.brighthub.com/computing/hardware/articles/53499.aspx
You don't type using your mouth.... <shrugs>
Then how dis happen?
You try putting an LGA1366 chip in a P55 board and see what happens. Why do you think the X58 test is there? For a comparison. Know what a comparison is?
Wait, why am I even wasting my time with this? I'd have better luck training a chimp.
9. The following statement is also false:you said:Dude, SB only has two 8x8 lanes to it in x-fire and SLI regardless
10. Since statement 3 is true, this statement is false:you said:There are no boards that can do 16x/16x, because the Sandy Bridge CPUs only have 16 PCI-e lanes. Some boards fake it by using a PCI-e bridge, which allows the manufacturer to claim the board is 16x/16x when it actually performs like an 8x/8x setup.
you said:Subsequently all P55 1156 chips support 16x16, it's up to the chipset to provide that support.
Quote upon quote!
Quote upon quote!
You're quoting yourself now? Wow, even I wasn't expecting to get you to end up talking to yourself. This should be fun to watch...
Why do you think they are releasing SB-E? to give more lanes, christ almighty, where on earth are you pulling a forced chip bridge of 16+16 that is actually 16x16? A SB will only accept a maximum of 16x PCI-E from graphics...
You show me a benchmark and proof that has a SB running at 16x16, I don't care about 1156 or 1366 as they are driven by chipset only.
Shame that's false, eh?mantic69 said:I don't care about 1156 or 1366 as they are driven by chipset only.
The nforce 200 works by multiplexing the lanes. There is still only a 16x feed to the CPU - that cannot change. What the nforce 200 does is take some of these 16 lanes, and then multiplex them, which allows a higher rate of bandwidth for the GPUs to communicate with the controller.
What this does, is allow the cards to communicate with themselves at full speed. This is all that's needed most of the time with crossfire/SLI, because they aren't being fed any more data, they're just rendering the scene three times over. When you use crossfire and SLI you don't actually need any more bandwidth to the CPU, all you need is bandwidth for the cards to communicate with each other. The nforce 200 provides this, and as a result negates the problem of not having enough bandwidth to the CPU. As the benchmarks show, it isn't perfect, but it does go a long way to fix the problem.
- usually I believe it's 8 of them, so you get an 8x master slot, and an 8x secondary slot - which becomes multiple 8x secondary slots, with a single 8x feed to the CPU. Hence why the nforce 200 never quite matches up to the performance of a true 16+16 chipset.me said:some of these 16 lanes
Mantic is right, its impossible to have 2x 16X on SB even with the NF200, you can't make additional artificial 16X lane, no matter what, not if the cpu don't meet the requirments.
