Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hi, does anyone have a laptop with this graphic card? I wanna overclock it a bit, but I'm afraid of overheating or something. So, what is safety cpu clock and memory clock value?
the success of ocing your mobile gpu depends on your laptops cooling solution. pretty much no two are a like. you can't use the clocks of someone who happens to have the same chip but in an entirely different laptop with an entirely different cooling design.
So long as you can game for several hours without experiencing crashing you're probably good. On some laptops the cpu and gpu are cooled by the same heatsink. So increase clocks while observing any heat increases by bothe cpu and gpu. As long as you can game without issue then you can continue to increase clock speed.
