Slartibartfast
- Sep 25, 2004
I won't disagree that 4x4 is a gimmick, personally I see no value in it whatsoever.
As for quad sockets, I did consider it.
Ockie said:You say 3% is nothing? lol
unhappy_mage said:Because Intel is on the upswing AMD didn't keep up their incredible upclimb, Intel came out with a chip they should have released years ago (Core Duo 2), and they fell approximately even for the first time in a while. Thus, people are turning on AMD in record numbers.
That said - if I want a dual-socket board, I want it server-grade. What reason would I have right now for an 8-core machine with no ECC? Most of the parallelized apps right now are server apps - web servers, SQL servers, distributed computing stuff, etc. None of which I'd consider running on a machine with no memory checking. Just that simple, as far as I'm concerned. Perhaps eventually, games will come out that use more than two threads, but until then it doesn't make sense to have a jillion cores.
I strongly disagree. If you had said Core 2 Quad, it might have made more sense.MrGuvernment said:4x4 is , well, more or less useless compared to core 2 duo.
visaris said:I strongly disagree. If you had said Core 2 Quad, it might have made more sense.
Fee said:they ever pick a socket yet? thats all i want to know lol
Arcygenical said:For single applications then yeah a C2D kicks the QF.
For anything with a high thread count / IO performance, AMD's system's quite useful.
Which OSes are you thinking of when you make this statement?uOpt said:If you study OS development you will also see that the memory allocation strategies for current OSes are entirely unable to make good use of NUMA because they always end up with the page in the "wrong" memory bank, unless they restrict the scheduler - which is even worse.
n1ce_hat said:Show me eight cores spread over two sockets, then i'll cash in.
Shingoshi said:There is no other way to secure all of the hours that we each invest in our systems, both in building and operating them, than to run those systems with ecc/registered ram. If you do anything else, you're foolish!! The next step in security is to run RAID1, 5 OR 6. You can always build hybrids of these. But at the most basic, one of these MUST be chosen. If you don't do this, don't shed one single tear the next time you have to reinstall your system.
Shingoshi said:But of course, for those of you running Windows, please just keep on crying. Windows 2000 (I'm guessing XP is no different) only allowed RAID0 if you didn't have a server edition. How pissed was I when I had a system go belly up because of that!! So I run Linux. Because it's the only intelligent thing to do. Linux provides you with security features Windows either doesn't provide, or charges you your firstborn child for. Spend your money on hardware, not software. Linux doesn't sing the blues!
Shingoshi said:Yes, I spent more than most, on a server board. But I have a Tyan s3992 with 16 DIMM slots, all of which are ecc/reg. And the prices are already falling on the Opterons (28)xxx series. I have a 2210, and the price has fallen @$40 [Newegg] since I got it a month ago. And yes I am hoping to get 8-cores on that board as soon as I can afford it.
Shingoshi said:But the one thing that ranks highest on my list of priorities, is stability. You can forget about it, if you're running anything without ecc/registered ram and RAID. DON'T run RAID0 on anything unless it is part of a hybrid RAID system. RAID10, RAID50 or RAID60. And even then, you're better of with RAID15 or RAID16. It's easy enough to set up.
RAID15: is mirrored RAID5. xxxx+r=RAID5
requires a minimum of one drive (r) for redundancy per stripe
/xxxx+r\
\xxxx+r/ These two lines represent RAID15
RAID16: is mirrored RAID6. xxxx+rr=RAID6
requires a minimum of two drives (rr) for redundancy per stripe
/xxxx+rr\
\xxxx+rr/ These two lines represent RAID16
Shingoshi said:Be the master of your world. Build a server.
Get fired up, and enjoy it!
ND40oz said:Looks like the processors and the Asus 680a is available at newegg now. Anyone want to be the guinea pig?
Here's the FX-72 and mb combo from NCIX.
ND40oz said:It does look like you're only getting one processor in the combo. In the past with the nForce opteron chipsets, you needed to have both processors to use both PCIe x16 slots. I don't know if it's the same way here. You may need to have both processors before you can take advantage of all the boards features.
