matrix563
- Sep 1, 2006
i just bought a second Q6600 for 135. amd just didn't have performance for me that i needed
It's weird. I bought a retail Phenom 9600 a couple of weeks ago for $105. Quad core for $105. Should be a no-brainer good deal, right?i just bought a second Q6600 for 135. amd just didn't have performance for me that i needed
After 7 months of being spoiled by overclocked Q6600 CPUs, the 9600 (TLB patch disabled) just doesn't feel fast or even feel like much of a bargain. It doesn't help that I can't overclock the 9600 either, and even if I could, with a stock cooler it wouldn't go much higher anyways.
The cherry on top is that the system ([email protected]/HD3870) at idle and load uses almost as much power as my main system's overclocked Q6600 @ 3GHz (Q6600@3GHz/8800GT) when configured similarly.
But you can go around and around with comparisons: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115052
The E7200 will beat the X2 5600+, for about the same price. If you want to start comparing prices, you have to wait until the cut is available.
Its $126 now, pre-price cut.. At $130 I would take the E7200 Wolfdale over that X2 5600 any day;
I figure it at less than 70% of the performance for 60% of the price of my first Q6600 ($170), plus I can't use it for virtualization (not a very good server) without a huge performance loss. The power consumption is what sours me on it the most.you got about 75% of the performance for half the price.
That's a big IF, and only if you need accelerated virtualization support, which ATM only is *required* by MS's WS2008 product.The catch here is that if you want virtualization support you have to step up to the E8200, while all of AMD's Athlon X2 CPUs feature it.
Most people don't need it and if they do, the E63x0 chips are available cheaper, but even lower end processors can run VMWare. I even run it on my low end laptop, although it limits 64-bit client usage.
I made the same suggestion as you did when the topic came up in the Intel forum a few weeks ago. Dual core AM2 CPUs are dirt cheap and it makes little sense to buy a more expensive Core 2 ($120 and up) or Pentium D 9x0 (bleh, but under $80 for a 3GHz model) when cheap X2s are around for lightweight virtualization loads. And I think the rev G Athlon 64 also has hardware support for AMD-V. I haven't bothered testing my AM2 3500+ with VMWare.Xen requires it for any Windows support at all, but I do see what you're saying.
