AMD Price Drops @ Outpost
enelson125 said:
Man, I was hoping for the 5000+ for under $300.
i'm waiting for the 939 4800 to drop.
question: would there be any reason NOT to just buy the highest cpu i can get after this price drop? like, is the 4600 better than the 4800 if i were using it in some other way or something? I'm not running a server or anything, nor many heavy duty applications at once, i'm pretty much just buying slightly overkill so i dont gotta upgrade for a long while. ihave a 3800 right now and it does fine, but it'd be nice to have the potential to be faster.is there anything i should know about why i prolly shouldn't buy the 4800 when it comes out at the lower price? like it runs single applications slower or it screws up game play or something (my 3800 had a problem properly playing GTA: SA cause it had both cores working against eachother, cause it to run either very slow or super fast.)
dang why is the 939 more expensive than teh am2 for teh 3800x2? its not fair...sniff.
I would try overclocking your 3800 first and see how far you can get. if you get to 2.6 or so stable, stay with it. if your dies around 2.2 or under (that's a pretty bad dud) and you feel like tossing some money out, go for whatever you can afford. The differences betwen the 512k and 1mb caches are negligable in most cases, pretty much non-existant in your case. The differences between a 3800 and 4800 stock won't prolong your desire to upgrade sooner, especially considering what you have stated you plan on doing. As far as the gta:sa issue, thats a dual core bug that can be fixed with patches and/or bios updates; the upgrade to 4800 would not make a difference since it too, would 'work agaisnt itself'.
I wonder what Fry's bundle deals will look like now. :)
Thread starter, there's no need for you to use ALL CAPS in the thread title.
I heard the 1 MB cache CPUs are not going to benefit from AMD's price drops. :( That sucks, but it's not like the 1 MB cache CPUs offered a significant performance increase compared to their respective 512 kB cache counterparts.
My guess is they feel that people with 939 orders are for people that already own systems, while AM2 orders are for new systems. 179 seems a bit high for the 3800+
but that's just me.
Just got off the phone with Outpost.com and they said that the AMD 5000+ is currently out of the stock. They are expecting shipments in on August 3rd.
:mad:
:mad:
Damn that sucks. I may just bite the bullet and grab a 3800+ and overclock the hell out of it.
Yeah, I am really tempted to grab a 939 X2 either 3800+ or 4200+. My old 3200+ Winny is getting a little long in the tooth, but I am going to see if AMD prices bottom out a bit more first. Just curious are the stock coolers on the X2's and Opty's the same as on the single core A64's?
Mwave had good prices to, but it looks like they've gone OOS since I looked earlier.
seems like Monarch is a good place to get the x2 3800 since outpost charges more for 939 and Newegg is 169.
