AMD PII X2 OC
Kynes
Well just built this setup couple weeks ago. Gotta CM Hyper 212+ on the processor temps are pretty good 25C idle 40-41C load. All 4 cores unlocked. 4GHZ stable at 1.4v.
MSI radeon 5770 @ 960 core 1400 memory 66C load Stock voltage . Dont really want to go any higher on it wont see that much performance increase.
4GB(2x2) Kingston Hyper X Genesis DD3 1600mhz @ 1666mhz right now with stock timing. Haven't really tried to push the memory much. Kinda like were it is.
New to the forums. last overclock I ever did was on a Athlon XP 2100 and A7N8X back in like 2002-3 or something like that. Wow things have changed a lot since then. All in all im impressed with this chip for only $90 I think it was a good deal and only $35 for the cooler.
Wondering if yall got any suggestions or im doing something wrong let me know.
http://valid.canardpc.com/show_oc.php?id=1773352
That looks really damn good. If you want to try and overclock farther, go for it, but otherwise, it looks fine. You have a lot of room in the performance envelop.
