Mr. Bluntman
- Jun 25, 2007
A thorought albeit blunt review. Good to know I switched to a Core 2 Duo when I did because Phenom II is certainly looking like a let-down clock-for-clock.
A) I'm idling right now at 2.63GB/4GB "used".
Stalker Clear Sky and Warhead will hitch with just 2 gigs of ram. I had to add another gig on my previous pc because 2 wasnt cutting it.Damn son, you must have a virus or something . Vista idles at about 1.1 / 4GB on my system, and around 400MB of that gets freed up when I launch a memory intensive application.
Also, might want to take a look at THIS website. It was the first one that popped up when I searched Google, but you'll see pretty much the same results everywhere you look.
Like Kyle said, 2GB normally gives you slightly better performance in games due to the lower latencies. Get out n00b.
I have a decent rig and some spare sticks of DDR2, I might do a quick Far Cry 2 2GB/4GB/8GB comparison later today. Kind of curious, myself. I know that my memory usage peaks quite high at various times, depending on what I'm doing, but that's on a system that's left on 24/7. On a fresh boot that jumps straight into a benchmark session, the 2GB might go slightly further. Although right now in Vista x64 I'm using an indicated 2.44GB and have little other than Firefox, AV and some IM clients running. It's my understanding that Vista grabs available memory to perform caching and reports it differently than XP did - leading to a higher indicated memory use on task manager vs XP, when the reality is that the usage is similar. I typically hover at about 1.1-1.2GB of used memory at a recently booted desktop.
In any event, I'll go get some popcorn.
Vista Prechaches the crap out of everything. Its constantly moving stuff in and out of memory, aggressivly, but that doesnt mean that for some reason its not actually using that memory.
§kynet;1033562300 said:"the damn Arabs" is that some sort of racist remark?
This is one of the worst reviews I have ever read on [H] and one of the worst reviews I have read in general. And you arguing that different amounts of memory on each platform don't matter, wow. The difference might not matter, but it may. As pointed out, a quality review removes as many variables as possible. It's common sense and good practice.
But I expect you to pull a fit, probably ban me, use several 4 letter words and claim how you know better than the "payed off" sites that are showing Phenom II is a much more favourable light.
All other reviews i see, there isnt this big diffrence between phenom 940 and qx9770. and the qx9770 and core 7 in games.
if you already have a good cpu then yes there wont be much difference. throw in an X2, Pentium D, or even a low end Core 2 like E2180 cpu and the cpu becomes pretty important in most newer games.thats because GAMES ARE GPU DEPENDANT!!!! when will people learn that?
Briefly back on the 2GB vs 4GB thing, it looks like Far Cry 2 does not exceed 2GB when the built-in benchmarker is used, regardless of settings. But only just... the engine itself uses about ~700-800MB and a bare vista boot sits just under a gig of allocated memory. No difference for the canned runs at 640x480/DX9/low or 1680x1050/DX10/8XAA/Ultra (max of my monitor) for any built-in run going from 2GB to 4GB. This may not apply to the other application suite tests or game tests but FC2 is fine. (Crysis: Warhead is well recognized as using more than 2GB right off of the bat, and it is reflected in the minimum FPS scores in benchmarks)
And of course, right after I swap out some sticks and reboot a few times, I find a similar comparison on CDRinfo.com: http://www.cdrinfo.com/Sections/Reviews/Specific.aspx?ArticleId=24373&PageId=6
Still, I'd be pretty uncomfortable benchmarking a system with less RAM than video memory!
Which is strange. TechReport gives a much more favorable review, and places the 940 has being roughly equal to the Q9400:
http://www.techreport.com/articles.x/16147
--In the Phenom II, AMD has produced a chip that comes strikingly close to duplicating the performance of Intel's mid-range Core 2 Quad processors, the Q9300 and Q9400.--
Guru3D pretty much comes to the same conclusion:
http://www.guru3d.com/article/amd-phenom-ii-x4-920-and-940-review-test/1
--See, when you place things in perspective, the $278 Phenom II X4 940 is here and there getting in close vicinity of that Core i7 920 processor. But let's compare to the Core 2 series for a moment. One thing we can definitely state is that Phenom II's performance is now comparable to the mid- to more high-end Core 2 Quad performance levels.--
So now I'm wondering whether something is up with [H]'s testing platform or not.
Tech-Report said:Some tough realities remain for AMD, but I'd say they're now tempered by a little more hope. Although the Phenom II is a marked improvement over the original 65nm Phenom, AMD still can't match the fastest Core 2 Quads in clock-for-clock or outright performance. And obviously, the Core i7 is yet another step beyond the Core 2.
You seem to have missed the rest of the Tech-Report's conclusion, which reflects what Kyle also reproduced in his article:
They missed the window of opportunity and the launch of Phenom II X4 doesn't have the desired effect on the market. The new Phenom II X4 doesnt look too impressive against the background of contemporary Core 2 Quad and especially Core i7 CPUs. The results of our tests show that the top Phenom II X4 processors can only be worthy rivals to the Core 2 Quad CPUs from the junior Q8000 series. Unfortunately, Phenom II X4 cannot yet do better than that.
wow this thread is turning into a love hate one! seems like some people dont like the review here
but core 2 uses ddr2 ram as well and core 2 boards are just as cheap as your beloved AMD board. can you price up a typical phenom 2 setup along with a typical quad core 2 setup please?you whoever you where who said its gpu dependant.
the benches are done on samy hardware in both tests, the qx9770 bested the core 7, and then suddenly it dont ?
uhm, both tests are done by hardocp, which makes this uhm ?
even though it doesnt beat core 2, its priced way lower, which makes it value. for now.
Legit Bottom Line: The AMD Phenom II processor series processor may not be the performance winner in all the benchmarks, but it might not need to be competitive in this day and age when the price tag matters most.
bit tech: AMD is getting back in the saddle, and we can't wait to see what 2009 will bring them, and us. Good stuff, very stable, nice , affordable and fast. What's not to like?
the whole core 7 platform is quite expensive. im using an cheap AM2+ board, in fact its half the price of core 7's cheapest board.
my memory cost me 40 bucks and i got 4 gigs.
the cpu will cost me abit, but still, its half the price.
Well as an AMD fan, I'm very disappointed.
When AMD says they are not competing with the i7 they are only fooling themselves.
I fully expect intel to dump prices on their Yorkfield line in preparation for the release of the i5 mainstream part. Enthusiasts will buy the new i7 and system integrators will most likely be able to move their existing inventory of mainstream intel hardware compared to new stock of AMD. Which pretty much leaves only people who have an AM2+ board to grab a PII 940 and overclock the crap out of it to make the most of their investment. That said I do admire the power savings on the PII. I hope all traces of the P1 are quickly remove as I cannot see them being a product anyone would want to buy now.
Kyle I think your review was fair & unbiased. I know as an enthusiast site, overclocking is the order of the day, but given your no BS, no fudge reviews I and others would love to see some straight out benchmarks of the PII 920 & vs the Q6600, Q9400 & Q9550 purely for value consideration when buying new systems from these now "mainstream" chips. I know we can get these elsewhere, but I simply trust your results more.
After reading the review I can only hope your problems with DDR2 1066 on the Phenom board are not an indication of a fault with your hardware as other sites were able to run at that speed without error. Bring on another round of BIOS updates.
Thanks again for the review, I'll start specing out my i7 upgrade now.
Danny
Kyle Bennett said: Please for the love of someones god, put down the bong and get sober before you mail this crap out."
not your best work Kyle. I don't think your conclusion is wrong, but how you got there leaves something to be desired.
In this particular case, you compared processors of a different nature, and (God knows why?) decided to install a completely different amount of memory into each test-bed system. Seriously man... ...what were you thinking?
Furthermore, it would have been more accurate to use a recent board (as in just released!),..the the board failed to operate with the memory running at 1066 MHz
