AMD PC keeps locking up. HELP!!!!!!
Hyper_Lite
I just installed some new equipement, and I'm having some problems. I was hoping someone could shed a little light on this one for me.Before this machine I had zero problems.
Things that have changed:
New 7800GTX
New Asus A8n motherbaord
New AMD Athlon64 3500+ cpu
The system will stop responding for a couple of seconds like installing things, or simply just listening to music. Personally I think its either the new AMD cpu, or my raid configuration.
The reason I think it is my RAID configuration is because I only have 2 IDE channels, and all my stuff is on IDE. This makes the 2 hard drives run Raid 0 on the same cable.
What that cause lock ups on my machine. The other reason I think it's the CPU is because the cpu % bombs to around 80% usage while doing simple tasks.
:confused:
Running a software-based stripeset on the same IDE channel is not a good practice.
The first thing I'd do is get your stripeset onto two separate IDE channels, ghost the data to another drive or back it up, then re-create the stripeset from the #3 and #4 SATA channels. You may have to disconnect your ROM drives temporarily in order to do this.
Alternatively, you could pick up a cheapo SiS 0680 RAID PCI card and run that way (after upgrading the drivers in the operating system) OR you could drop some serious wad on a 3ware hardware-based controller. Personally, I'd do the latter.
You didn't mention your PSU. That may be an issue if it's a generic one.
Antec True 420, but like I aaid my hd's are ide not sata, and they're on hardware RAID.
i think he was implying put one drive on a cable for raid. so dont put both hd on the same cable and it shouldnt lag. thats how i did it on my old comp anyways.
