Simmonz
- May 14, 2008
When I use AMD Overdrive to overclock my CPU it for some reason makes my CPU speed fluctuate as if cool and quiet were turned on. Sometimes my CPU speed will be 4300 MHz but other times it will be 800 MHz. My CPU speed stays at the 3400 MHz default when Overdrive is uninstalled so it is not an OS issue. I have gone into power options in the control panel and set CPU to always be at 100% but Overdrive still does it. Any ideas how to fix this ? I can't use my BIOS to overclock because there is no option to change the multiplier.
