AMD overdrive and vista 64
Valset
any way to get it to work? crashes any time I use it or say it doesn't have enough permission to to work. Overclocking seems to suck anyways on vista 64 but this is just stupid.
any ideas would be nice, and bios overclocking is not an issue at this point do to not being able to disable the TLB fix. (I am never going to buy another DFI board on that account)
Run it as administrator. You must also know that under vista 32 you gain better overclocks that with vista 64. I know, it sounds weird but it is due to the bigger number of active registers(some kind of ultra high speed memories inside the cpu) under vista 64.
I knew both but I did get it to work somewhat now. I had to drop back a version. oddly what doesn't work is the stability test. it crashes the system even at stock speeds. but everything else says that it is stable. I could probably push it to 2.7 but don't see the need. what I really needed it for was to disable the TLB patch, goddamn DFI took that option out of the bois.
I may try the 790GX and see how that does.
