- Apr 6, 2012
I decided to call AMD one last time to find out what is going on with releasing drivers that support multi gpu setups like tri / quad fire + eyefinity, etc.... before I moved to Nvidia.
The AMD rep stated that tomorrow morning you can go to their website under Support & Drivers and type in the search bar located in the upper right "Catalyst 12.6 beta".
He stated that the 12.6 beta will fix the Tri /Quad, eyefinity, BSOD, etc...crossfire issues and will include all previous enhancements/improvements from previous releases. This driver applies to 7900 and 7800 series cards.
If they are full of crap and it doesnt work I will most likely give up on AMD and go Nvidia. /fingers crossed
Good Luck!
Good Luck!
