Heya peeps.
I'm trying to find a new motherboard without much success atm.
The requirements are that is needs 4 SATA connectors, and preferably onboard PATA RAID as well.
HSF mounting holes are required as I want to move to watercooling.
Onboard Gigabit LAN would be a big plus too.
I'm currently running an Athlon 2400+, but would consider moving to an Athlon64 if the mobo is going to set me back a bit (no point in an expensive upgrade if I have to turn around and do it again soon - doesn't worry me so much if it's fairly reasonable cost).
My mobo atm is a Gigabyte GA-7N400 Pro
Other components are:
9600Pro
2x SATA 120gb
2x PATA 120gb
2x PATA 200gb
Samsung Combo drive
And no, the drives aren't full of porn! in fact there is none on them at all![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Any suggestions are appreciated
9600Pro
2x SATA 120gb
2x PATA 120gb
2x PATA 200gb
Samsung Combo drive
