AMD Master setting
antok86
Im running a 3600 ryzen and installed ryzen master and running amd ryzen balanced power option. Can someone tell me what the default minimum power state should be. I was messing with it and didnt realized it doesnt let you default restore....it was like 90% or 99% cant remeber
Rvenger
99% but I set mine to 5% like in the regular balanced plan which helps with idle.
