AMD & Intel alternatives for building a higher mid-range system
njc
I'm trying to build a system, and i have about 550 bucks in the budget for the CPU/motherboard/RAM ... What would be the best way to go... what has the highest performance in that price range, an AMD or an Intel product? What motherboards and what memory? Should i got the DDR2 route?
Well, amd would give you better gaming performance, be sure you get ethier the k8t800 pro chipset or nforce3 chipset. As for ram, depends if your overclocking, if not buy pc3200 ddr, mushkin, geil, ocz, corsair, and kingston the good brands. If you do plan on overclocking you will probably want to get some higher frequency ram.
Be sure to get a s939 motherboard and cpu, the 90nm amd64s are better than the 130nm ones, but price should be a major factor in what speed you get.
Check pricewatch.com for stores
Here is the setup I ordered on thanksgiving
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1087917&CatId=1619
I also picked up a 512mb stick of geil pc4000 memory for overclocking at newegg.
http://www.newegg.com/app/ViewProductDesc.asp?description=20-144-314&depa=0
And a heatsink for $17 off of some small store, the tigerdirect deal didnt include one.
As for DDR2 they are more expensive and generally slower than an equal frequency ddr.
