fusiondog70
- Dec 18, 2016
hey guys Im a new to all this stuff gut what would be to hot for the 8350@ 4.4 under a load Im getting like in between 55 to 60 degrees celuis is this to hot thanks
Thanks alot just didnt want to hurt the cpu thats allNo. it is just at the high point. 65C is the general consensus for max, 72C is the throttle limit.
First and foremost make sure to cool your VRMs, they are next to the little boxes that surround the CPU, usually between the CPU and the connections for the back panel and sometimes along the top of the CPU. If they get hot they will quickly throttle the CPU.
Also, not necessary, you can put a fan on the back of the CPU socket if your case allows.
4.4Ghz is the usual max OC on air while still keeping temps within check.
