AMD FX-8350 for $179.99 @Amazon.
cageymaru
For those of us that live 5 1/2 hours from a Microcenter, here's a pretty sweet deal for you. Amazon seems to have lowered their prices on the FX series. More than likely after they sell a few the software they use will raise the price back up. So be quick!
AMD FX-8350 for $179.99.
AMD FX-8320 for $144.99.
AMD FX-6300 for $119.00.
Enjoy!
How do these 8-cores compare with, say, an i7 Ivy Bridge?
No offense, but there are dozens of reviews you could check. But most of them will tell you that in single-threaded apps, an i7 will be a little better to a whole lot better, and in multi-threaded apps the FX will be slightly behind to slightly ahead.
If you do a lot of multi-threaded apps, it's a good choice. Also VM's will take advantage of more cores. If it's solely gaming, you will probably be fine at ~1080p 60Hz, but double and triple SLI/Crossfire would probably be better served by an i5/i7
I have two very similarly set up systems(check my sig) and the only diff being the Mobo and the 2600k and 8350. I will say that when I play games at realistic resolutions and settings(IE MAX) , I can't tell a difference between the systems in games. And in Handbrake the 8350 does a good job. AT this current price, Intel really has nothing that competes overall in my mind.
If I had a mobo that supported the FX series then I would likely jump on this. But alas I will just have to stick with my 965 running at 300x12.5 :D
Sometimes life can be hard, and we all have our burdens to bear :)
