Computer Specs:
OS: Windows 7 Home Premium
Mobo: ASUSTeK M5A97
CPU: AMD FX-4100 3.6 GHz Quad Core
GPU: EVGA GeForce GTX 670
RAM: 16 GB Patriot DDR3 1333MHz
PSU: CoolerMaster 850W
Res: 1680 x 1050 (SyncMaster 225BW)
I'll stop any troll attempts here by saying that with this build, I have no problems whatsoever with running every game at max settings, 60+ FPS. The only exceptions are TERA Online and Guild Wars 2, which have issues that CPU bind / Bottleneck most CPUs. TERA's won't be fixed for a long time, but GW2 will have it fixed upon release.
One of the issues I am having with this Processor of mine, is that I love to game, and I want to start using XSplit more so I can livestream.
...But then there's a snag in the road...
The issue I have, is that when I run XSplit, my CPU Usage jumps up to 45%. If I turn that off, and run a game, it jumps my CPU Usage to 67%. Keep in mind, all of my games, and XSplit itself, are set at Normal priority with the CPU, meaning I haven't messed with any of that, since it is the default setting.
I am concerned about this in two ways:
1. If I run XSplit and a game at the same time, and start recording, since I am maxing out the Usage, the FPS is hit really hard, and I can't do much if I game.
2. A friend of mine has an AMD Processor as well, but his is a 3.3 GHz Quad Core, a little less powerful than mine. However, when he has both a game running, and XSplit livestreaming, his CPU Usage is only at 42%.
This makes no sense whatsoever.
I would appreciate it if anyone can help me with what I could possibly do to fix this issue. What kind of tests do I need to run? If I have to run any, post links and walk me through it.
What can I do, without buying a new processor and mobo, since I can't right now, to fix this?
Mobo: ASUSTeK M5A97
