Holy crap, the thread starter is right! As I noted above, I had no problems viewing that site and pic w/ my company Dell laptop and Mozilla 1.0.5. But upon trying this w/ my Venice 3200+ and Firefox 1.0.6, CPU usage got pegged to 100%. Also, my CPU temp went up by 1 deg. C.beowulf7 said:No problems with my Intel Pentium M laptop with Mozilla 1.0.5. I will try w/ my Venice 3200+ and Firefox 1.0.6 sometime over the weekend.
That's b/c those other sites are not W3C compliant.todlerix said:off topic, sorry
I dont use firefox cuz its got a ton of compatibility issues (sites)
I've never tried Maxthon but might give Opera a try now that I have it when they gave out licence key codes last week.Try maxthon, it uses ie6 engine, gives tabbed browsing internal ad blocking (like the ones that scroll across the screen) or banners
Unknown-One said:This has more to do with nVidia cards than AMD processors, here's the fix:
i have a 6800GT, AGP.Unknown-One said:start posting what video cards you've got, I'd like to get to teh bottom of this![]()
With your CPU usagelithium726 said:i have a 6800GT, AGP.
Unknown-One said:With your CPU usage![]()
yours truly said:just opened the site, i get 0-5% usage with a bunch of other shit open on a 2.4ghz x2
ChingChang said:Coloreal Bright takes up the same amount of CPU usage as F@H did.
ChingChang said:possible, but why doesn't IE take so many CPU cycles with macromedia animations running? I still think it's a flaw with firefox.
That theory is incorrect b/c when I run Mozilla (which has a larger footprint than Firefox) w/ a Pentium M laptop, that site didn't affect its CPU utilization.ChingChang said:possible, but why doesn't IE take so many CPU cycles with macromedia animations running? I still think it's a flaw with firefox.
I don't know about that specific gif, but I do know that many IE windows open never slowed down my system, but firefox always does. Because of all the animated images.Topweasel said:As Posted earlier by me and a few other people IE does use that many CPU cycles, in fact for me while both peg my cpu hard, only IE acts sluggish while that gif is on the screen.
kbeowulf7 said:That theory is incorrect b/c when I run Mozilla (which has a larger footprint than Firefox) w/ a Pentium M laptop, that site didn't affect its CPU utilization.
Same here. 6600GT, 1.8Ghz winchester core s939.ChingChang said:Blame firefox, not your hardware, or that site.
I've had this problem since I started using firefox. I usually leave a ton of windows with tabs open, and after awhile I'd notice everything became slower. Games would get very choppy, and I'd check the task manager and see my game with like 20% usage, firefox with 80%. It never happened when I used IE.
