getSIDEWAYS
- Dec 12, 2006
well my AMD 5200+ is running great but i noticed that core# 1 runs almost 10c hotter than core # 2 at an idle, does this mean i didn't put my heat sink on right? im using everest to get this temps
getSIDEWAYS said:well my AMD 5200+ is running great but i noticed that core# 1 runs almost 10c hotter than core # 2 at an idle, does this mean i didn't put my heat sink on right? im using everest to get this temps
Sta!nless said:someone posted a quote about how some of the chips could have been shipped with bad and or inacurate temp probes. Still it could be a bad mounted IHS, If it's not what do we do?
Sta!nless said:^^^^^^^ Yeah see...so I'm wondering which core we should go by?
Well for me as I type this and the chip is pretty much idle, my temps are 40C and 20c. I'm on water with no IHS, and room temps are 70F... If the colder core Was read in Fahrenheit, it'd be 64 degrees. Like I said room temps are 70.. So what's reporting what wrong? I guess either way I'm glad it doesn't load up past 48C.
I think CoreTemp is just crap - because when I turn on Prime95, my Coretemp readings shoot up 10C instantly. Turn it off, they shoot down 10C instantly.
No way that is real, and since the sensors are reading voltages, probably a voltage spike causes this when the CPU is suddenly loaded.
Sta!nless said:Well for me as I type this and the chip is pretty much idle, my temps are 40C and 20c. I'm on water with no IHS, and room temps are 70F... If the colder core Was read in Fahrenheit, it'd be 64 degrees. Like I said room temps are 70.. So what's reporting what wrong? I guess either way I'm glad it doesn't load up past 48C.
I have a 3 degree difference at idle, and 6 at load.
I too was wondering about the way the temp rises so fast. When I shut off orthos it drops back to idle temps in .05 seconds lol.
Another thing I noticed was that CORE 0 would display a NEGATIVE temp whenever I start up BF2.... Alt-tabbed out of BF2 after the map is loaded, and coretemp still shows a negative temp for Core 0. Issue disappears when BF2 is shut down... core 0 temp returns to normal. Very odd.
NordicRX8 said:Wow... big temp difference for a no load situation. My temps are only apart by 1-2c when at idle, but under load, Core 1 starts to pull away and I end up with a 12-15c difference between cores.
I think the IHS will be taken off this weekend if that doesn't help the difference in temps between the cores... at least it'll lower temps a few degrees
According to PC Probe II, both of my cores are running at 10C with my 9500 CNPS and about 5 fans.
However, my BIOS says 40C.
Whatever.
