So I built a new PC
MSi-970 gaming Motherboard
AMD 8350 CPU
Dual MSI-480 8 GB video card
1000 watt power supply
Windows 10
I used it for roughly 2 weeks. everything was fine. I went to use it the other day and black screen on monitor, the monitor was getting signal but no display. Reset everything past the Post was black screen. Take computer apart re assemble it. Same thing. Some googling Tells me its the AMD drivers for the video card.
So far i have tried to install AMD
16.9.2
16.9.1
I install it, and 3 minutes into the install screen goes black. An hour later I reset the computer and the drivers are not installed. I used the AMD CC cleaner between installs.
I am downloading 16.7.3 currently to see if it works. Any ideas anyone?
AMD 8350 CPU
Windows 10
16.9.2
16.9.1
