AMD CPU Specifications Thread
Kaiga
Thank you Mr. Bennet for taking care of the last thread. Folks, this is the new revised thread to take care of the big Gaps and the 20000Character post limit, I have reserved extra posts so that this thread can be formatted properly and look a Whole lot better. :)
[]AMD Specs Thread by: Kaiga and support of fellow [H]ard Forum Members.[]
I thought i should contribute to the AMD CPU section. Hope it Helps.
[font=&quot]This is just a guide on the AMD processors you can quickly refer too. I will be updating this thread on a regular basis, making sure that everything is correct, and to add new processors.
[/font] AMD Athlon 64 Dual Cores:
[font=&quot] AMD Athlon 64 X-2 Dual Core Processors:
>AMD64 technology provides full-speed support for x86 code base for uncompromising 32-bit performance, ready for 64-bit applications
>40-bit physical addresses, 48-bit virtual addresses
>Support for 3DNow!™ Professional technology Plus SSE3
>Eight new (8x2=16total) 64-bit integer registers
>Eight (8x2=16total) 128-bit SSE/SSE2/SSE3 registers
AMD Athlon 64 X-2 3800+
Socket 939
Core: Manchester
Clock Frequency: 2000MHz (2.0GHz)
HT Speed: 2000
CMOS Technology: 90nm SOI
Voltage: 1.40V
Thermal Power: 89W
Max Temp: 71'C
L1 Cache: 128KB
L2 Cache: 512KB + 512KB
Stepping: E4
AMD Athlon 64 X-2 4200+
Socket 939
Core: Manchester x2
Clock Frequency: 2200MHz (2.2GHz)
HT Speed: 2000
Voltage: 1.40V
Thermal Power: 89W-110W
Max Temp: 65'C
L1 Cache: 128KB +128KB
Stepping: E4
AMD Athlon 64 X-2 4400+
Socket 939
Core: Toledo x2
HT Speed: 2000
Voltage: 1.40V
Thermal Power: 110W
Max Temp: 65'C
L1 Cache: 128KB+128KB
L2 Cache: 1MB+1MB
Stepping: E6
AMD Athlon 64 X-2 4600+
Socket 939
Core: Manchester x2
Clock Frequency: 2400MHz (2.4GHz)
HT Speed: 2000
Voltage: 1.40V
Thermal Power: 110W
Max Temp: 65'C
L2 Cache: 512KB+512KB
Stepping: E4
AMD Athlon 64 X-2 4800+
Socket 939
Core: Toledo x2
HT Speed: 2000
Voltage: 1.40V
Thermal Power: 110W
Max Temp: 65'C
L2 Cache: 1MB+1MB
Stepping: E6
[/font]
AMD Athlon 64 FX-60 Dual Core
Socket 939
Core: Toledo x2
Clock Frequency: 2600MHz (2.6GHz0
FSB: 1GHz
Cache: L1: 256Kb (128KB + 128KB) | L2: 2MB (1MB + 1 MB)
Voltage: 1.35V - 1.40V
Thermal Power: 110W
Max Temps: 65°C
Stepping: E6
____________________________
[font=&quot]
AMD Athlon 64 Processors:
(!!--NOTE: SOCKET 939 CPUS USE 128-BIT MEMORY CONTROLLERS. 754 SOCKET CPUS USE 64-BIT MEMORY CONTROLLERS.--!!)
AMD Athlon 64 2800+
Socket 754
Core: Clawhammer
Clock Frequency: 1800MHz (1.8GHz)
System Bus: 1600
Process: 0.13Micron
Operating Mode: 32/64
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 512KB
AMD Athlon 64 2800+
Socket 754
Core: Newcastle
System Bus: 1600
Process: 0.13Micron
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 512KB
AMD Athlon 64 3000+
Socket 754
Core: Newcastle
System Bus: 1600
Process: 0.13Micron
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 512KB
AMD Athlon 64 3000+
Socket 939
Core: Venice
Clock Frequency: 1800MHz (1.8Ghz)
System Bus: 2000
Voltage:
[/font]1.35V-1.40V
[font=&quot] Max Temp: 65' C
Thermal Power: 67W
L1 Cache: 128KB (64kb+64kb)
L2 Cache: 512KB
AMD Athlon 64 3000+
Socket 939
Core: Winchester
System Bus: 2000
Voltage: 1.40V
Max Temp: 70'C
Thermal Power: 67W
L1 Cache: 128KB
L2 Cache: 512KB
AMD Athlon 64 3200+
Socket 754
Core: Newcastle
System Bus: 1600
Process: 0.13Micron
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 512KB
CMOS Technology: 130nm SOI
AMD Athlon 64 3200+
Socket 939
Core: Venice
System Bus: 2000
Voltage:
[/font]1.35V-1.40V
[font=&quot] Max Temp: 65'C-70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 512KB
CMOS Tehcnology: 90nm SOI
AMD Athlon 64 3200+
Socket 754
Core: Clawhammer
System Bus: 1600
Process: 0.13Micron
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 1MB
AMD Athlon 64 3200+
Socket 939
Core: Winchester
System Bus: 2000
Voltage: 1.40V
Max Temp: 70'C
Thermal Power: 67W
L1 Cache: 128KB
L2 Cache: 512KB
AMD Athlon 64 3400+
Socket 939
Core: Newcastle
System Bus: 2000
Process: 0.13 Micron
Voltage: 1.40V - 1.45V
Thermal Power: 67W
L1: 128 KB / L2: 512KB
AMD Athlon 64 3400+
Socket 754
Core: Newcastle
System Bus: 1600
Process: 0.13Micron
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 512K
AMD Athlon 64 3400+
Socket 754
Core: Clawhammer
System Bus: 1600
Process: 0.13Micron
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 1MB
AMD Athlon 64 3400+ DTRWMobile
Socker 754
L2 Cache Size: 1MB
TDIE Max: 95°C
Max P-State 1800 MHz (1.8GHz)
VID_VDD: 1.50 V
IDD Max: 52.9 A
Thermal Design Power1: 81.5 W
Thermal Resistance (case to ambient): 10 0.65°C/W
Intermediate P-State:#1 1600MHz
VID_VDD: 1.40V
IDD Max: 39.1 A
Thermal Design Power1: 57 W
Min P-State: 800 MHz
VID_VDD: 1.10V
IDD Max: 15.3 A
Thermal Design Power1: 19 W
Halt/Stop Grant Max P-State2:
IDDC1 Max 29.5 A
I/O Power6 2.2 W
Halt/Stop Grant Min P-State3:
IDDC1 Max 5.0 A
I/O Power6 2.2 W
C3/S1 Min P-State4:
IDDC3 Max 3.5 A
I/O Power6 2.0 W
I/O Power7,5 600mW
AMD Athlon 64 3500+
Socket 939
Core: Newcastle
System Bus: 2000
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 512KB
AMD Athlon 64 3500+
Socket 939
Core: Venice
System Bus: 2000
Operating ModeL 32/64
Voltage:
[/font]1.35V-1.40V
[font=&quot] Max Temp: 65'C-75'C
Thermal Power: 67W
L1 Cache: 128KB
L2 Cache: 512KB
AMD Athlon 64 3500+
Socket 939
Core: Clawhammer
System Bus: 2000
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 67W
L1 Cache: 128KB
L2 Cache: 512 KB
AMD Athlon 64 3500+
Socket 939
Core: Winchester
System Bus: 2000
Voltage: 1.40V
Max Temp: 70'C
Thermal Power: 67W
L1 Cache: 128KB
L2 Cache: 512KB
AMD Athlon 64 3700+ 1MB
Socket 754
Core: ClawHammer
System Bus: 1600
Process: 0.13Micron
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 67W
L1 Cache: 128KB
L2 Cache: 1MB
AMD Athlon 64 3800+
Socket 939
Core: Venice
System Bus: 2000
Process: 0.13Micron
Voltage:
[/font]1.35V-1.40V
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 512KB
AMD Athlon 64 3800+
Socket 939
Core: Newcastle
System Bus: 2000
Process: 0.13Micron
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 512KB
AMD Athlon 64 4000+ 1MB
Socket 939
Core: Clawhammer
System Bus: 2000
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 1MB
[/font][font=&quot]--
Socket 939
Core: San Diego
System Bus: 2000
Voltage: 1.35V-1.40V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 1MB
[/font]
[font=&quot]----
AMD Athlon 64 FX-51
Socket 940
Core: SledgeHammer
System Bus: 1600
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
Cache: L1: 128KB / L2: 1MB
Stepping: C0
AMD Athlon 64 FX-53
Socket 940
Core: Sledgehammer
System Bus: 1600
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
Stepping: CG
AMD Athlon 64 FX-53
Socket 939
Core: ClawHammer
System Bus: 1600
Voltage: 1.50V
Max Temp: 70'C
Thermal Power: 89W
L1 Cache: 128KB
L2 Cache: 1MB
Stepping: CG
AMD Athlon 64 FX-55
Socket 939
Core: ClawHammer
Clock Frequency: 2600MHz (2.6GHz)
System Bus: 2000
Voltage: 1.50V
Max Temp: 63'C
Thermal Power: 104W
L1 Cache: 128KB
L2 Cache: 1MB
AMD Athlon 64 FX-55
Socket 939
Core: San Diego
System Bus: 2000
Voltage: 1.40V
Max Temp: 63'C
Thermal Power: 104W
L1 Cache: 128KB
L2 Cache: 1MB
AMD Athlon 64 FX-57
Socket 939
Core: San Diego
Clock Frequency: 2800MHz (2.8GHz)
System Bus: 2000
Voltage: 1.40V
Max Temp: 63'C
Thermal Power: 104W
L1 Cache: 128KB
L2 Cache: 1MB
[/font]
AMD Duron Processors:
Duron 1.6GHz
Core: Applebred
Socket: Socket A
Operating Frequency: 1.6GHz
FSB: 266MHz
Cache: L1/64K+64K; L2/64K
Voltage: 1.5V
Process: 0.18Micron
AMD Duron 1.8GHz
Core: Applebred
Socket: Socket A
Operating Frequency: 1.8GHz
FSB: 266MHz
Voltage: 1.5V
Process: 0.18Micron
Opteron:
(!!--NOTE THAT ALL OPTERON 940 SOCKET PROCESSORS USE 144-BIT MEMORY CONTROLLERS--!!)
[font=&quot]AMD Opteron Model 240
Core: Hammer
Socket: Socket 940
Operating Frequency: 1.4GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/1024K
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 940
AMD Opteron Model 242
Core: Hammer
Socket: Socket 940
Cache: L2/ 1MB
Voltage: 1.65V
Process: 0.13Micron
AMD Opteron Model 244
Core: Hammer
Socket: Socket 940
Cache: L2/ 1MB
Voltage: 1.5V
Process: 0.13Micron
AMD Opteron Model 246
Core: Hammer
Socket: Socket 940
Operating Frequency: 2.0GHz
Cache: L1/64K+64K; L2/ 1MB
Voltage: 1.5V
Process: 0.13Micron
AMD Opteron Model 248
Core: Hammer
Socket: Socket 940
Operating Frequency: 2.2GHz
FSB: Integrated into chip
Voltage: 1.5V
Process: 0.13Micron
AMD Opteron Model 250
Core: SledgeHammer
Socket: Socket 940
Operating Frequency: 2.4GHz
Cache: L1/64K+64K; L2/1MB
Voltage: 1.5V
Process: 0.13Micron
[/font]
AMD Opteron 144
Socket 939
Core: Venus
Multiplier: 9x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 146
Socket 939
Core: Venus
Multiplier: 10x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 148
Socket 939
Core: Venus
Multiplier: 11x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 150
Socket 939
Core: Venus
Multiplier: 12x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 152
Socket 939
Core: Venus
Multiplier: 13x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 154
Socket 939
Core: Venus
Multiplier: 14x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 165
Socket 939
Core: Denmark
FSB: 1GHz
Cache: L1: 128KB (64KB+64KB) L2: 2MB (1MB+1MB)
Process: 90nm
Voltage: 1.30V-1.35V
Wattage: 110W
Case Temperature: 49°C - 65°C
Amp: 80A
Stepping: E6
AMD Opteron 170
Socket 939
Core: Denmark
FSB: 1GHz
Process: 90nm
Wattage: 110W
Amp: 80A
Stepping: E6
AMD Opteron 250
Socket 940
Core: Troy
Clock Frequebcy: 2.4 GHz
FSB: 1GHz
Cache: L1: 128KB / L2 1MB
Voltage: 1.4V
Process: 90nm
AMD Opteron 252
Socket 940
Core: Troy
Clock Frequency: 2.6GHz
FSB: 1GHZ
Voltage: 1.5V
Process: 90nm
AMD Opteron 254
Socket 940
Core: Troy
Clock Frequency: 2.8GHz
FSB: 1GHz
Cache: L2: 1MB
Voltage: 1.35V/1.4V
Process: 90nm
AMD Opteron 270 Dual Core
Socket 940
Core: Italy x2
Clock Frequency: 2.0GHz
FSB: 1GHz
Operating Modes: 32/64
Cache L1: 128KB / L2: 2MB
Voltage: 1.3V-1.35V
AMD Opteron 265 Dual Core
Socket 940
Core: Italy x2
Clock Frequency: 1.8GHz
FSB: 1GHz
Voltage: 1.3V-1.35V
AMD Opteron 275 Dual Core
Socket 940
Core: Italy x2
Clock Frequency: 2.2GHz
FSB: 1GHz
Voltage: 1.3V-1.35V
AMD Opteron 865 Dual Core
Socket 940
Core: Italy x2
FSB: 1GHz
Voltage: 1.3V-1.35V
AMD Opteron 870 Dual Core
Socket 940
Core: Italy x2
FSB: 1GHz
Voltage: 1.3V-1.35V
Socket 940
Core: Italy x2
FSB: 1GHz
Voltage: 1.3V-1.35V
Member Contributions:(and thank you for the contributions, it just helps this thread everytime it gets posted in. :))
Thank You 54YW4T:
54YW4T said:
2800+ ADA2800AEP4AP ClawHammer
2800+ ADA2800AEP4AR ClawHammer
2800+ ADA2800AEP4AX Newcastle
3000+ ADA3000AEP4AP ClawHammer
3000+ ADA3000AEP4AR ClawHammer
3000+ ADA3000AEP4AX Newcastle
3000+ ADA3000DAA4BP Venice
3000+ ADA3000DAA4BW Venice
3000+ ADA3000DEP4AW Newcastle
3000+ ADA3000DIK4BI Winchester
3200+ ADA3200AEP4AX Newcastle
3200+ ADA3200AEP5AP ClawHammer
3200+ ADA3200AEP5AR ClawHammer
3200+ ADA3200DAA4BP Venice
3200+ ADA3200DAA4BW Venice
3200+ ADA3200DEP4AW Newcastle
3200+ ADA3200DIK4BI Winchester
3400+ ADA3400AEP4AX Newcastle
3400+ ADA3400AEP5AP ClawHammer
3400+ ADA3400AEP5AR ClawHammer
3500+ ADA3500DAA4BN San Diego
3500+ ADA3500DAA4BP Venice
3500+ ADA3500DAA4BW Venice
3500+ ADA3500DEP4AS ClawHammer
3500+ ADA3500DEP4AW Newcastle
3500+ ADA3500DIK4BI Winchester
3700+ ADA3700AEP5AR ClawHammer
3700+ ADA3700DAA5BN San Diego
3800+ ADA3800DAA4BP Venice
3800+ ADA3800DAA4BW Venice
3800+ ADA3800DEP4AW Newcastle
4000+ ADA4000DAA5BN San Diego
4000+ ADA4000DEP5AS ClawHammer
4200+ ADA4200DAA5BV Manchester
4400+ ADA4400DAA6CD Toledo
4600+ ADA4600DAA5BV Manchester
4800+ ADA4800DAA6CD Toledo
FX-51 ADAFX51CEP5AK ClawHammer
FX-51 ADAFX51CEP5AT ClawHammer
FX-53 ADAFX53CEP5AT ClawHammer
FX-53 ADAFX53DEP5AS ClawHammer
FX-55 ADAFX55DAA5BN San Diego
FX-55 ADAFX55DEI5AS ClawHammer
FX-57 ADAFX57DAA5BN San Diego
FX-59 ADAFX59DAA5BN San Diego
Thanks: CFECLIPSE
Processor AMD Athlon 64 Mobile
Model 3700+
Ordering P/N (Tray) AMN3700BKXBU
Ordering P/N (PIB): N/A
Stepping E5
Frequency 2400Mhz
HT Speed 1600
Voltage 1.35 V
Max Temp 95°C
Thermal Power 62W
L1 Cache 128KB
L2 Cache 1MB
CMOS Technology 90nm SOI
Socket 754
Model 4000+
Ordering P/N (Tray) AMN4000BKXBU
Stepping E5
Frequency 2600Mhz
HT Speed 1600
Voltage 1.35 V
Max Temp 95°C
Thermal Power 62W
L1 Cache 128KB
L2 Cache 1MB
Socket 754
AMD Opteron 148
Socket 939
Core: Venus
Multiplier: 11x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 150
Socket 939
Core: Venus
Multiplier: 12x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 152
Socket 939
Core: Venus
Multiplier: 13x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 154
Socket 939
Core: Venus
Multiplier: 14x
L1 Cache: 128KB
L2 Cache: 1MB
Thanks: -Chem-
[font=&quot] AMD Athlon 64 X-2 3800+
[/font]ADA3800DAA5CD
[font=&quot]Socket 939
Core: Toledo x2
HT Speed: 2000
Voltage:
[/font]1.3-1.4v[font=&quot]
Thermal Power: 110W
[/font]
[font=&quot] Max Temp: [/font]65c
[font=&quot] L1 Cache: 128KB+128KB
L2 Cache: 1MB+1MB but with 512KB+512KB disabled
Stepping: E6
Thanks: MD
[/font] Processor AMD Athlon 64
Model 3700+
Ordering P/N (Tray) ADA3700DAA5BN
Ordering P/N (PIB) ADA3700BNBOX
Stepping E4
Frequency 2200Mhz
HT Speed 2000
Voltage 1.35-1.40 V
Max Temp 70°C
Thermal Power 89W
L1 Cache 128KB
L2 Cache 1MB
Socket Socket Socket 939
Thanks: Someonewhoisntme
AMD Opteron 144
Socket 939
Core: Venus
Multiplier: 9x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 146
Socket 939
Core: Venus
Multiplier: 10x
L1 Cache: 128KB
L2 Cache: 1MB
Thanks: SirFragAlot
AMD Opteron 254
Socket 940
Core: Troy
FSB: 1GHz
Cache: L2: 1MB
Voltage: 1.35V/1.4V
Process: 90nm
[font=&quot]
AMD Sempron Processors:
(!!--NOTE: SOCKET 754 SEMPRONS HAVE 64-BIT MEMORY CONTROLLERS--!!)
AMD Sempron 2200+
Core: Thoroughbred
Socket: Socket A
Operating Frequency: 1.5GHz
FSB: 333 MHz
Cache: L1/64K+64K; L2/ 256KB
Voltage: 1.6V
Process: 0.13Micron
AMD Sempron 2300+
Core: Thoroughbred
Socket: Socket A
Operating Frequency: 1.583GHz
FSB: 333MHz
Voltage: 1.6V
Process: 0.13Micron
AMD Sempron 2400+
Core: Thoroughbred
Socket: Socket A
Operating Frequency: 1.667GHz
FSB: 333 MHz
Voltage: 1.65V
Process: 0.13Micron
AMD Sempron 2500+
Core: Thoroughbred
Socket: Socket A
Operating Frequency: 1.75GHz
FSB: 333 MHz
Voltage: 1.6V
Process: 0.13Micron
AMD Sempron 2600+
Core: Thoroughbred
Socket: Socket A
Operating Frequency: 1.833GHz
FSB: 333MHz
Voltage: 1.65V
Process: 0.13Micron
AMD Sempron 2800+
Core: Thoroughbred
Socket: Socket A
Operating Frequency: 2.0 GHz
FSB: 333MHz
Voltage: 1.65V
Process: 0.13Micron
AMD Sempron 2800+
Core: Palermo
Socket: 745
Clock Frequency: 1600MHz (1.6GHz)
FSB: 333MHz
Cache: L1: 128KB / L2: 256KB
Voltage 1.65V
Process: 90nm
AMD Sempron 2800+
Core: Thorton
Socket: Socket A
FSB: 333MHz
Voltage: 1.65V
Process: 0.13Micron
AMD Sempron 3000+
Core: Palermo
Socket: Socket 754
Operating Frequency: 1.8 GHz
FSB: 400MHz
Cache: L2/ 128KB
Process: 0.09Micron
AMD Sempron 3100+
Core: Paris
Socket: Socket 754
Voltage: 1.5V
Process: 0.13Micron
AMD Sempron 3000+
Core: Barton
Socket: Socket A
FSB: 333MHz
Cache: L1/64K+64K; L2/ 512KB
Voltage: 1.65V
Process: 0.13Micron
AMD Sempron 3300+
Socket 754
Core: Palermo
System Bus: 1600
Voltage: 1.40V
Max Temp: 70°C
Thermal Power: 62W
L1 Cache: 128KB
L2 Cache: 128KB
AMD Sempron 3300+
Socket A (462)
Core: Barton
Voltage: 1.65V
Max Temp: 85'C
L1: 128KB L2: 512Kb
CMOS Technology: 0.13 Micron
[/font][font=&quot]AMD XP Processors:
AMD Athlon XP 2500+
Core: Barton
Socket: Socket A
Operating Frequency: 1.83GHz
FSB: 333MHz
Cache: L1/64K+64K; L2/512K
Voltage:55W 1.65V
Process: 0.13Micron
AMD Athlon XP 2600+
Core: Thoroughbred
Socket: Socket A
FSB: 333MHz
Wattage: 55W
Voltage: 1.65V
Process: 0.13Micron
AMD Athlon XP 2600+
Core: Barton
Socket: Socket A
Operating Frequency: 1.9GHz
FSB: 333MHz
Wattage: 55W
Voltage: 1.5V
Process: 0.13Micron
AMD Athlon XP 2700+
Core: Thoroughbred
Socket: Socket A
Operating Frequency: 2.17GHz
FSB: 333MHz
Cache: L1/64K+64K; L2/256K
Voltage: 1.65V
Process: 0.13Micron
AMD Athlon XP 2800+
Core: Barton
Socket: Socket A
Operating Frequency: 2.08GHz
FSB: 333MHz
Voltage: 1.5V
Wattage: 55W
Process: 0.13Micron
AMD Athlon XP 3000+
Core: Barton
Socket: Socket A
Operating Frequency: 2.16GHz
FSB: 333MHz
Voltage: 1.65V
Process: 0.13Micron
AMD Athlon XP 3000+
Core: Barton
Socket: Socket A
Operating Frequency: 2.1GHz
FSB: 400MHz
Voltage: 1.65V
Process: 0.13Micron
AMD Athlon XP 3200+
Core: Barton
Socket: Socket A
FSB: 400MHz
Voltage: 1.65V
Process: 0.13Micron
AMD MP:
AMD Athlon MP 2800+
Core: Barton
Socket: Socket A
Operating Frequency: 2.13GHz
FSB: 266MHz
Voltage: 1.65V
Process: 0.13Micron
_____________________________
[/font]
-----Post reserved for more CPU Profiles-----
That should do it!! note: I have taken Care of the Memory Controller issues for the Socket A Semprons. Thanks again mods and fellow [H] Members!
there are 2 or 3 types of AMD64 4000+ processors.
You only list one.. Does it matter?
54YW4T said:
What about Mobile Processors?
I will be adding more Mobiles soon to this thread, I still have work to do one some of the other processors. But this is still in my list to do.
This I am still working on, I realize that there are other types of 4000+, other cores, I will be adding these shortly to this list. thank you for the concern.
well people, I have answered your prayers (actually PMs.) and I have fixed a few things on the list, such as the AMD 4000+, I have given it a twin, behold! the San Diego.
I haven't been on the forums for a few days because I got a big job I scored to setup a nice big fat network at an office for a company. I still have to go in and finish it up, and today I am beat dead. Cat5 cabling can become hefty when they're around like in the 200's. now, enough about me, I have some news about the AMD Mobiles, I will be updating on those soon enough once I find a more reliable source for the details. I have never done anything with mobiles, I will admit it, my laptop does not have the power of AMD, but rather the Intel hammer. perhaps my friend Hakira can help me since he practically sleeps with mobiles, and you know, takes them out to dinner every once in a while, buys them nice clothes (components)) but enough of that. I will soon have teh 4/\/\|) /\/\081∟3$.
(!!--NOTE: ALL DURONS HAVE 32-BIT MEMORY CONTROLLERS-!!)
that's a function of the motherboard. a single channel of DDR = 64 bit.. you can put a duron into an nforce2 board that's 128bit
also, i just noticed something.. stock voltage for the X2. i don't know if it varies, but most of the ones i'm seeing are stock at 1.3v
What does this mean?
I have this mobo:
Shuttle AN35N-Ultra Socket A (Socket 462)
and just bought 2 gigs ddr400 patriot dual channel ram. Will this ram work when i go with socket 939 and 3700 san diego???
the other questions don't belong in here, but yes
64bit memory controller = single channel ddr
128bit = dual channel ddr
yep they can vary although I dont see this nearly as often on AMDs as I do on intels
Could anyone clarify "Stepping" which is better 4 or 6 in the X2 chips?
Thank you and sorry, I can delete this if you want
please do not post questions in this thread, this thread is used for information on the above, please make a thread for that or search.
but to answer your q, 4 is the better of the 2.
and thank you 54YW4T for the list, it shall be added to the list.
Where is a 3700+ San Diego?
Model 3700+
Stepping E4
Frequency 2200Mhz
HT Speed 2000
Voltage 1.35-1.40 V
Max Temp 70°C
Thermal Power 89W
L1 Cache 128KB
L2 Cache 1MB
MD
in that vein, the 3700+ and 4000+ newarks are missing too :D
Model 3700+
Stepping E5
Frequency 2400Mhz
HT Speed 1600
Voltage 1.35 V
Max Temp 95°C
Thermal Power 62W
L1 Cache 128KB
L2 Cache 1MB
Socket 754
Model 4000+
Stepping E5
Frequency 2600Mhz
HT Speed 1600
Voltage 1.35 V
Max Temp 95°C
Thermal Power 62W
L1 Cache 128KB
L2 Cache 1MB
Socket 754
note: i think all the revE cpu's (san diego, venice, lancaster, newark, toledo, manchester) should actually be:
CMOS Technology 90nm DSL SOI
The Opteron Troy core and dual core Italy processors should be added.
add socket 939 opterons, they should be about this:
AMD Opteron 144
Socket 939
Core: Venus
Multiplier: 9x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 146
Socket 939
Core: Venus
Multiplier: 10x
L1 Cache: 128KB
L2 Cache: 1MB
dont forget:
AMD Opteron 148
Socket 939
Core: Venus
Multiplier: 11x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 150
Socket 939
Core: Venus
Multiplier: 12x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 152
Socket 939
Core: Venus
Multiplier: 13x
L1 Cache: 128KB
L2 Cache: 1MB
AMD Opteron 154
Socket 939
Core: Venus
Multiplier: 14x
L1 Cache: 128KB
L2 Cache: 1MB
and the dual cores, but i'm busy ;)
AMD Opteron 254
Socket 940
Core: Troy
FSB: 1GHz
Cache: L2: 1MB
Voltage: 1.35V/1.4V
Process: 90nm
These babies ROCK! :D
A bit OT, but from your machine stats in your sig, doesn't running those (size) miss matched memory modules (say that ten times fast) hamper your system performance a bit? or does the addition of the two 512mb corsair ECC modules add something of value? other than just ant extra gig?
They don't hamper anything. The Opteron doesn't have the same memory controller issues the A64 does. It adds nothing other than a GB either. The memory was laying around so I threw it in. It's going to come out when I get the parts to finish my other Opteron box. I'll throw that gig in there.
NUMA support is a funny thing. I have to have 4 exactly matched memory modules in slots 1 and 2 for each CPU, (typical dual channel configuration) but I can't have a third stick in each CPU's memory slots. I have to have the two extra chips in slots 3 and 4 of CPU 2 in order to keep NUMA support on. If I place them in any other configuration, they'll work of course but they'll disable NUMA and possibly dual channel support depending on how I install them.
This is all listed in the K8WE's manual. Sure enough, my Sandra scores are right where they should be for a NUMA enabled Opteron setup, and it confirms NUMA is on.
ok - well I figured you wouldn't have your system in a non optimal state, but I wanted to ask... seems like a lot of dual proc systems I have dealt with at work... it's almost litterally like two fully populated single proc mobos (nodes) combined... they can share resouces via the hardware bridging (interconnect bus) in the chipset, NUMA being part of that... I reckon. :)
numa.... nuuuuma . . . nnnnnnuuuuma... numa! flashing back to Caddy Shack... heh ;)
Yeah, there are two of almost everything on that board. Two chipsets (Technically three if you count the AMD 8131 PCI-X Tunnel chip) two NICs, two video card slots, two processor sockets with two sets of two memory banks. Two CPU's.
Dual everything. :cool:
Yes sir... it also makes your sig very intimidating. plus, two is better than one, one is the loneliest number. ;)
Yes, to that end I was considering another 600Watt PSU.
[font=&quot]not on amds website but i have one here in mine hands, maybe someone else knows the less obvious stats[/font][font=&quot]
Core: Toledo x2
HT Speed: 2000
Voltage:
Thermal Power: ?????
[/font]
[font=&quot] Max Temp: [/font]51-71c
Stepping: E6
[/font]
wow you guys, I feel a bit terrible for abandoning this thread for a short-while, but I am back to put up/update new profiles, I have just had work/studies crunching me in but I am over that "crunch" and I am back to fixing this thread up nicely. :)
Core: Toledo x2
HT Speed: 2000
Voltage:
[/font]
Stepping: E6
[/font]
that max temp right.....51' scary?
