AMD Cool N Quiet...
Copyright
Do you have to run the AMD cpu cooler for this to work? Im using a stealth Ninja 6 Plus but on a fan controller.. what I was hoping for was it to throttle the CPU down at idle. I dont see it working tho. I have it enabled in Bios and the driver is loaded. If it wont work with this cooler or has to have a fan plugged into the mobo im just gonna turn it off.. Thanks for any input on this!
No, it will work with any cooling as its software not hardware based. It can be alittle flakey if you overclock, but at stock settings its a nice power saver.
Have you enabled the minimum power management in windows? See if that helps. Some boards like my MSI Neo2 Plat need have that enabled in order to get the cool'n quiet working. But that is not always the case. My A8N32 doesnt need it.
Yeah im a tard.. I should have done more reading.. when I enabled minimum power management everything started working perfectly. Very kewl how it works.. normal temps are 35C at idle , 46C full load, 32C at idle with Cool N Quiet. Plus I guess it helps with power consumption and wont let me room get as hot when its at idle.
you should be folding!
