I currently run 3 monitors and have 2 profiles set up.
The first one is set up for eyefinity and works fine when disabling it and re-enabling it.
the second one is 1 desktop with 2 extended desk tops, however when I re-enable this profile it always mixes the screen order up. What I mean by this is it extends them wrong.
For example this is what is usually does.
I have 3 screens we will lable them 1,2,3
1 is the far left screen
2 in the primary center screen
3 is the far right screen
I have them saved in the profile as [1][2][3] and it works fine.
However when I switch to my eyefinity profile then back to the 3 extended screen the order changes to:
[2][3][1] --> so what happens is my center screen is still the primary, but then instead of 1 screen on each side I have 2 screen extending to the right
Anyone know why this happens and how can I fix it. its not hard to change the order in CCC but its annoying cause I switch back a forth a lot since eyefinity doesn't work is some games.
