AMD Catalyst 12.1 Preview Driver 32-64-bit driver
By Hilbert Hagedoorn, December 13, 2011 - 11:08 PM N/A - 0 Comments
AMD would like to share a preview of AMD's 12.1 Catalyst driver. Not only does this driver raises the bar on performance and fixes a few issues, but it also introduces quite a few new features, as well as UI enhancements. You'll find the list of changes below.
AMD HD3D technology support enhancement
Enables support for AMD HD3D technology in conjunction with AMD CrossFireX configurations
Delivers a new Stereo 3D mode over HDMI 1.4a connections - 1080p at 30Hz is now enabled on supported displays.
AMD Catalyst Control Center / Vision Engine Control Center enhancements Application Profiles
AMD Catalyst 12.1 Preview driver enables users to create per application profiles to individually control 3D and CrossFireX settings for Direct3D applications.
Please be sure to select the Restore Factory Defaults option under the Catalyst Control Center Preferences menu before using the new application profiles feature this ensures there are no compatibility issues between previous drivers and the new AMD Catalyst 12.1 Preview driver with regards to application profiles
AMD Catalyst Control Center / Vision Engine Control Center enhancements Video UI improvements
AMD Catalyst 12.1 Preview driver includes user interface enhancements to simply adjustment of video color and video quality controls
Performance highlights of the AMD Catalyst 12.1 Preview driver (in addition to the AMD Catalyst 11.11c performance driver). Improves performance (10%) in Elder Scrolls: Skyrim when Multi-Sample Anti-Aliasing is enabled on the AMD Radeon HD 6900 Series for single GPU and AMD CrossFireX configurations
We have a discussion thread open right here. You can download the driver (32 and 64-bit) for Windows Vista and 7 right here.
http://downloads.guru3d.com/downloadget.php?id=2826&file=4&evp=8c1ce11f20e2679be3b64db596303940
