Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Amd boost for some reason automatically comes on every time I start up my pc. This drives the core temp up about 5 degrees. Ive tried everything to disable it. Is there some way to disable it through bios? or do I just need to uninstall amd overdrive?
there should be a setting so that it doesnt start up with windows.. that or you can remove it from the startup folder.. or go into run.. msconfig and under the startup tab disable amd boost..
