Many do claim they rush right to the benchmarks and don't even look at the test system specs.
Fast food times we live in...
Hey I only read the first half of your post, can you post the second part again here so that I can read it?
Regardless of what drivers they are using, the benchmarks seem a lot lower then most of the review sites...especially in Grid at 2560x1600.
Again, who cares? if they use some random benchmark with beta drivers, that has no real relation to how the card will perform with stable, final-build drivers in real gameplay. I hope they like their shiny graphs and wholesale conclusions that mean ABSOLUTELY NOTHING in terms of the way that the game performs in real life on MY system.Regardless of what drivers they are using, the benchmarks seem a lot lower then most of the review sites...especially in Grid at 2560x1600.
Is this solved with 8.8? Read about this problem about a month ago.
Actually playing a game vs. a time demo creates very different results.
What drivers did they use?Problem with this is that driverheaven doesn't use time demos in Grid...
I think your numbers are way off. The fact you guys were not able to enable 4xaa at 2560x1600 in grid on the 4870x2 seems quite strange. Of course I see you are using adaptive for some reason...![]()
omg...just please stfu already![]()
Sorry, when every other review shows a different story, I'll question the one that doesn't make any sense. So how about you stfu, seriously![]()
driverheaven said:what this does not show is that the game suffers from random drops in performance on the X2 which result in the reduction of framerates, sometimes for a few seconds and at other times until the game is restarted.
HardOCP said:We have chosen to do our run-through in the Race Day Pro Tuned mode in Okutama on the Grand Circuit with three laps.
Then we record with FRAPS across several in game levels recording the averages.
Thank you very much for the review, Brent and Kyle.
What kinds of fps do you get with 2xaa and 4xaa? Are they below 25 fps avg as well?
Has anyone tried one of these one UT3, or any other UE3 games? Just wondering since this seems to be the one game that the newer ATI cards don't handle as well as the nVidias. I just can't decide anymore, I think 'Ah, finally this MB/CPU/ ohhh, wait , but what about, nope that wont work' and then have to start over![]()
I really need to upgrade...
Blackforge
Personally I'd get your cpu clock speed up to 3.2 to 3.4. Also make sure you have the latest Grid patch installed. I'd also monitor those temps...and try to bump up the 4870x2 fan speed manually to 50% temporarily to see if the problem goes away. If you don't know how to adjust your video card fan manually, I can tell you how.
Oh and what drivers are you using?
UT3 caps it's FPS to 60FPS by default. You can over ride that if you want but I don't feel like its' necessary. On the 4870 X2 it just sits at 60FPS all the time rarely dropping below 55 even at 2560x1600 with 8xAA and 16xAF. (This was off of one 4870 X2 mind you.)
well that would make sense but the GTX260 SLI numbers must be a typo also because theres no way it could be drawing 260watts more than a single GTX280. why is nobody else even questioning these numbers because they are clearly a mistake?![]()
To measure power consumption on these video cards, we used a Kill-a-Watt in-line power monitoring device from P3 International. Please note that the power usage numbers listed below reflect total system power usage. The Kill-a-Watt device sits between the wall and our power supply, so the power readings shown reflect the total amount of power our test computer used.
nösferatu;1032985937 said:good read. i thought it would takes gtx280 SLI to match HD 4870x2 because 4870x2's multi gpu scaling runs so well, i was wrong, gtx260 SLI matched HD 4870x2 perfectly. thanks [H].
how can it draw 540 watts under load when the system draw with single 4870 is only 280? theres NO way those numbers can be correct because a second 4870 gpu cant possibly pull 260 watts by itself.
sorry if this was already answered but I skimmed through the comments and didnt see it mentioned.
That's what it was, I've double checked, I used total system power at the wall and used Grid to gauge peak power as I noticed it was demanding the most GPU activity with the 4870 X2.
I am tired of you trashing HardOCP in every post. I can take criticism, but you are obviously here to troll. Take it elsewhere. You no longer have access to our video card forums. - Kyle
