I currently have my Athlon 64 3500+ venice core OC'd at ~2.6GHz from the stock speed of 2.2GHz (on STOCK cooling). I think I had to up the core voltage to about 1.52v. I didn't have to change anything with my memory, as I'm pretty sure it's running stable at 237MHz (I have 2GB of Corsair Valueselect DDR400).
So, my questions are:
1.) How do I lock the PCI/AGP speed? The only option I see in my BIOS (I have an Abit nForce 4 Socket 939 mobo) pertaining to this is a PCI clock that is set to 100MHz by default. Is it possible that there is a PCI/AGP lock by default and I don't have to change anything?
2.) Assuming that this overclock is stable, would it be safe to leave it OCed at 2.6GHz or is this pushing it too far? Under load I'm pretty sure the temp has stayed below 55 Celsius.
