AMD 65nm Overclocking Database
nice start... :D
but, since this is the 2nd post of a new page... READ THE FIRST POST CAREFULLY
i hate sorting through posts that don't have the information i need. if you don't have the stepping, week number, etc, everything i listed, it's NOT GOING UP. :mad: :p
I didn't want you to put it up yet. I just now put the chip in, and that's the first thing I started at and it amazed me how much these chips like to OC. I will have the necessary information when completed..
Josh
i actually meant that post for the 10 or so people who had posted before you that aren't in the database, but thanks for the reassurance :)
AD03600IAA5DD
CAALG 0706TPBW
310x9.5
1.32v
35/43 ºC AC64 Freezer Pro
Abit NF-2 mATX mobo
Super Talent DDR2 667 at 840
http://valid.x86-secret.com/show_oc.php?id=184691
This probably isn't my maximum overclock. I just put Shin Etsu on since I had to remove my heat sink to install my new 8800GTS 640.
BOOO!! I'm not actually booing you, but I think I got one of the not-so-good steppings, I mean, only a 850 Mhz overclock? This brizzie sucks!
I want 1Ghz though....
I believe that's what I have, and most others on here. It's a Brisbane (65nm core), dual core, 3600+ which is 1.9 Ghz. That's in pounds though? Dang, I bought mine for ~66 DOLLARS!
thanks for the info
it's not in pound but in euros but it's still expensive maybe I'll get the E4300 instead :/
updated the rules slightly.. since this thread is turning into a discussion, please send me a pm with the results to get into the database. ;)
edit, massiveoverkill added.
anyone else who isn't up.. PM ME! :D
also, why do we only have 3600+ results? :confused:
Needed to be updated.... 2.85 @ sitting at 51 at load.. Core temp is at 38
I have written down almost all my information at home, so that I can pm you.. but I cannot get all of the information because I'm having a hard time getting an accurate temperature, so it is keeping me from getting posted.
Speedfan is showing like 10C on both cores..
In bios I'm idling at 37C, which I think this is the correct temp.. however, I cannot find out my load temps like this..
FWIW: I am running ~3ghz... +/- 10mhz.
As soon as I can figure out this problem, I'll have all my information ready.. any idea's?
Thanks,
Josh
everest is doing the best at reading my temps for my 3600 brizzy, maybe try and dl that?
coretemp/speedfan are both way off on temps, giving me 10c or stuff like 127c.
