AMD 64 Stock HSF Specs?
logo29a
Does anyone know where I can find the specs of the stock HSF for the AMD64 processors? I wasn't able to come up with it on the AMD site. What I really want to know is the cfm and noise levels of the stock fan so I can use it as a guide to purchase a cooler unit.
je suis pas certain mais tu devrais acheter le nouveau cooler de gigabyte (3D Cooler) si je me rappelle bien du nom.
si tu est canadian tu peux l'acheter chez www.vibecomputers.com
I am not certain but you should buy the new Cooler Gigabyte (3d Cooler) if I remember name well. If you are Canadian you can buy it at www.vibecomputers.com
That has absolutely nothing to do with the question I asked. It's easy to find information on aftermarket coolers. What I want is information on the stock unit.
