Ok I have an AMD 64 atholn 3400+ on a gigabyte ga-k8vm800m MB. When I try to increase the FBS past 212 my computer will not load past the XP loading screen. what should i do?
At idel my temp is only 35c
Before you continue doing anything with the computer, be sure to read this guide thoroughly. It'll walk you through overclocking, the problems you may face, and how to overcome them.
