- May 4, 2006
Hi this is my first OC and i wanted to know if this CPU can go higher then 2.67Ghz @ 1.5V. here is a pic EDIT: the stock was 2.4Ghz @ 1.39V
an exceptionally good questionquadnad said:Also, have you determined that it's prime stable at that speed?
quadnad said:Well, considering each proc will max out at different speeds, you're really going to be the only one with the correct answer to your question. Is that the max? Perhaps at 1.5v, but if your temps are fine why not head to 1.55?
LOCO LAPTOP said:Prime is stable for 24 hours without crashes
PS it crasher as soon as i hit apply @ 1.55
LOCO LAPTOP said:now i didruns a 1.55V stable so far
those it mean i can hit 2.8 if i do it by bios
quadnad said:are you asking if you can hit 2.8 in the bios?
no, that's something about the fan control. it's at 33c in that shotkill4killin said:is that 72C really??? YIKES thats hot
35 idle isn't too bad, but it's load temps that countLOCO LAPTOP said:i used to, but i use bios. i overclocked @ 2.7Ghz at 1.55V... 35C idle, a bit high?
(cf)Eclipse said:35 idle isn't too bad, but it's load temps that count![]()
LOCO LAPTOP said:Ok i got my computer to stay stable at this speed.
stormshadow said:this thread was fun to watch as the speeds got higher and higher...
for a second, i was expecting a screenshot of the blue screen or something eventually lol.
nice work on the clock. with your new project and potentially better cooling, we may be in for more scrshots!
LOCO LAPTOP said:mine wont go higher then 2.7Ghz stablewhats up with that?
