AMD-64-2800 too little ?
water1
I have a AMD 64-2800 pushing a plain old vanilla GF6800, well not anymore because it died.
I can get a 256mb ATI X1800xt.
Would the AMD 64-2800 be too little to power it ?
Would I at least get a big jump in frame rates with this pair even if the AMD 64-2800 isn't pushing the X1800xt to it's limits ?
dont listen to people who say the 6800 wont live to what it can...
if they do say that...
your regular 6800 is fine with that processor
as for the 1900xt i would up the processor if you can so you can play to the max:)
edit..
Yeah if your cards dead go for that but if you can get like a 4000 would be great for that card
or higher
Do you have a 2800+ NewCastle 754 chip? If so, have you tried possibly overclocking in the range of 2.0-2.4? I think if you could get it at or above 2.0 you wouldn't really be limited much by it at all. You would see a gain in framerates for sure going from a 6800NU to a X1800XT, probably a rather large gain.
If you decide against it, you could get a 3200+ Venice and a 7600GT for ~$300 (assuming you are 754 and running @ stock). Of course, it may not be the best time to invest in 754.
With the price of the X1800XT's lately, I'd say go for one. They won't last at this price forever, and you can easily keep the X1800XT for quite awhile even after other system parts are upgraded.
The 6800Nu is Dead as in broke, Not working anymore.
The CPU is a 754 but I don't know if it's a New Castle.
One more thing, if I do go X1800xt, should I go 256 or 512 meg ?
What resolution do you want to game at? If it's 1280 or below, go for the 256mb for sure. If you are gaming in 1600 or higher, the 512mb may actually come in handy.
out of curiosity, i did some testing in Lost Coast's benchmark (admittedly not the best test but w/e)
no difference between 1.8ghz and 2.8ghz. jump from a 6500 to a 7900gt was tremendous.
I'd have to say that the video card is more important than the the cpu in most 'modern' cases.
ep1taph, I have a 19"LCD so I will be at 1280*1024.
Cool Test Least, thanks for posting your find. You have any input on 256meg or 512meg video card ?
go for the 512 if you can swing it ..as you'll get a bit more life out of the card
the 512 will help if you like your eye candy in todays games and will most definately be a plus to help push future games without having to resort to butt fugly settings
the source engine is much more dependant on cpu than video cards.
He is right a cpu upgrade from an axp-m 2500 @ 2.3 to a dothan 730 @ 2.6 basically doubled my fps on my 9800 on the source engine. It all depends on what games you play to what kind of gains you will see.
I'd say upgrade the CPU. Going from a 2800+ to a 3400+ clawhammer (2.2ghz) I've noticed a big improvement in games. The 3400 just feeds my vid card faster.
