Amd 5200+ temps?
tronics
I've got a 5200 and was wondering what temps should it be sitting idle at, just for my own curiosity. The bios shows it sitting anywhere from 41 C to 44 C. Is that high? I'm using the stock heatsink. Thanks
gdonnel
Mine is running currently at 2.7GHz on water at 28C (winter) to 38C (summer).
DeChache
The BIOS will show higher Idle temps than in windows because none of the power saving stuff kicks in. Grab Core Temp and see what your temps are in windows.
tronics
Thanks for the replies. I'm hovering at 33 C to 35 C. Thats at stock speeds. Witha zalman cooler on it.
