So i have an AMD 3800 venice with an XP-90C bonded with ceramique and a 92mm fan...currently im at 1.58-1.60v on the CPU and hitting load temps at @ 49c. If i up the voltage to 1.68v so that I could overclock from 2788 to 28XX, would my current cooling system help...also i have 2 120mm case fans and 1 side 90mm fan. Would it be safe to go to that high a voltage on AIR cooling.
one more question...would a ssytem running the memory at 166mhz (for stability) be slower than a system with the memory at 200mhz. Im assuming yes but the CPU speed I attain at 166mhz is 88mhz faster than if i left the memory speed at 200mhz (1:1)?
