anybody know to to set the display via DVI port? it seem it only display from HDMI, i have 6yr old benq monitor
pretty sure its not the cable since it was work with my previous gtx470
If your monitor uses a single link DVI cable, then be sure you're plugged into the correct DVI port on the card that supports single link DVI. HERE is a link with pics/diagram to help you determine which connections are dual link on the card and which ones are single link DVI.
note: Your cards connection positions may differ from the diagram I linked.
So you should physically look at the pin layout on each output on the card to determine the right one that matches your monitors cable.
Be sure and pick the port that matches your monitor cable exactly since a single link monitor cable will still plug into a dual link output on the card, but you'll get no signal.
