Guys I am in the middle of a water-cooling project and would like to connect two 290 video cards with a "bridge", basically trying to make it look clean and not just put a regular tube in between. What do I purchase to connect the two?
Do your blocks match? Who makes them? If you're buying the EK blocks EK makes a link connector thinger than goes between. You just need to buy the one that fits the correct spacing (i.e. 2 slot or 3 slot etc.)
I have the Asus Maximus Hero motherboard so I am using the 2 red PCI16 slots. I have the EK waterblocks for the 290/290x. I cant figure out which one I need to connect the two because I am confused on the spacing.
You have 3 slot spacing between those two slots. Activate:AMD is correct that there is a gap where another PCI slot could go right underneath the top PCIe x16.
